Persistent Windshield Washer Issue
Old Jan 26, 2025 | 07:56 PM
squareskin's Avatar
squareskin
1st Gear
Default Persistent Windshield Washer Issue
Hey Gents, recently picked up a C7 in good condition. Was really excited and it drives well but I noticed the windshield washer does not work.
I'm fairly mechanically inclined so I followed the steps on other threads and found the pump wasn’t running and swapped it out. Now the pump makes an audible noise when I hold down the windshield washer lever but nothing comes out. There’s definitely fluid in there; maybe the tubes are clogged up but in that case what have some of you done to free them up? What else might it be and what steps should I take?
Thank you!!
Old Jan 26, 2025 | 08:23 PM
aklim's Avatar
aklim
Assuming the pump is fully working and the motor is not just turning, can you disconnect the hose and see if water comes out?
Old Jan 26, 2025 | 08:34 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Try disconnecting the hoses at the wiper blades to find out if fluid is moving up there.
Old Jan 26, 2025 | 10:12 PM
Good suggestions in the above two posts. Hopefully it is a simple fix.
Old Jan 27, 2025 | 10:39 PM
jaki30's Avatar
jaki30
Found clogged nozzles preventing fluid spray.
Used a small piece of wire to open the nozzles.
To Persistent Windshield Washer Issue
