Brakes Worn Message + Cruise Control Not functioning
Is the message of Brakes Worn related to Cruise Control? No errors on the whole PCM except the brakes worn message
the plastic tab part inserts into the pad and simply wears away over time until the wire is exposed. Once the wire is exposed, you get the light on your dash. I can’t imagine someone so cheap to spend the ungodly amount of money on the pads, but to simply cut off the wires and stare at the warning all day.
Front 23316707
Rear 23300243
Front 23316707
Rear 23300243
When you reference Pre Wires are you referring to wires such as 1610, 1612, 1613 and 4081 that are shown connecting the sensors?
Bill
Bill
What we can see from the schematic is Wire 1612 goes from Pin 9 of the EBCM mounted on the driver's side in front of the serpentine belt on the engine. There is no indication whether this is just a single white wire dropping from the EBCM to the brake wear sensor connector on the driver's side of the cradle or if it's part of a harness that goes that way. The wire for the left front wheel speed sensor goes from the EBCM to the left front wheel so it seems logical there might be a harness that routes and protects those wires. Then we have wire 1613 traveling across the front cradle to reach the right front wear sensor connector. Is that a single thin wire or is it part of a harness? Now we get to the area we are interested in: the right front brake wear sensor is connected to connector X174 Pin 40 and from that pin to the right rear brake wear sensor through 1611. Connector X174 is located on the lower right side of the engine. As I mentioned before this connector connects two harnesses, the engine harness and the transmission harness there is no indication other than the Pin 40 reference that this wire passes through these two harnesses, there isn't any indicator but the schematic that indicates there may be two wires connected at Pin 40. From the FSM, I surmise there is more than one transmission harness. There may be several serially connected to go the distance from the engine to the transmission/other circuits located at the rear of the car. Then wire 1610 travels across the rear cradle to reach the left rear brake wear sensor. From the left rear brake sensor, wire 4081 travels to connector X174 Pin 34 and from there wire(circuit) 4081 connects Pin 34 to EBCM Pin 23. I doubt you would want to replace the harnesses as they would be a huge PIA to replace. Individual wires may be easier to replace but I doubt it would be easy. I suspect the break in your circuit maybe with the wire that runs from the right rear to the left rear brake wear sensors or in the 4081 circuit that is more than likely inside the harness that goes from the rear of the car to connector X174. If the problem is in a connector it could be due to a pushed pin or a broken wire. To start I would double-check the rear sensors to see if there is continuity between Pins 1 and 2 on each of the sensors, then check the continuity of wire 1610, then check the continuity of circuit 4081 from the left rear to the EBCM pin 23.
As for replacing broken wires, I would rather splice them.
Bill
Bill
Another question please, I couldn't find rear brakepad sensors, instead I found the front ones. Do you think they will fit? I am not sure if there is anything difference apart from the front seems to be longer?
Wires from both calipers run similar paths and go up along the back surface of the diff. A pigtail comes off for each AFM valve. It looks like they join above the diff and go through a 2" grommet into the body of the car. I didn't have much luck getting light to the grommet so I did a green outline showing where it is. I hope the PO just removed the sensor wires at the connectors. If you have to get into the heat shielded harness that will not be fun.
The connector seems to be 13580874 of a part number?
The connectors for the brake wear sensors are located on the cradle near the Ride Control Suspension Movement sensor. Here is the left-side brake caliper showing the CCM pads, the location of the sensor on the pads and the sensor wire passing through a notch in the caliper body. From there the sensor wire runs alongside the caliper body until it turns and if I remember correctly (my CCM brakes have been in boxes for 9 years) is clipped to the ABS sensor harness until it reaches the cradle where it is connected to the car wiring. The connector is tied down tightly to the cradle so you have to loosen the covering some in order to remove the sensor half of the connector.
Here is a diagram from the FSM showing how the Brake Wear Sensor Harness is routed from the caliper toward the cradle:
If the sensor has been removed from the pad just follow the ABS sensor harness to the cradle and look at the top of the cradle for an empty connector. The rear wear sensor connectors are located further inboard on the cradle than the front connectors. I remember when I changed the stock pads at the track I could access the front wear sensor connectors from the wheel well while I had to crawl under the car to access the rear wear sensor connectors.
Some people may have removed the sensor pill from the brake pad and looped the sensor back along the ABS harness. The system has no idea if the sensor is located on the brake pad. It only knows if the electrical current path is broken. When I went to the AP Racing brakes I just looped my sensors back toward the cradle and made sure they couldn't come loose from the ABS harness.
Bill
