Security system warning
Old Apr 21, 2025 | 10:03 AM
wolfganggardner's Avatar
wolfganggardner
Default Security system warning
Does anyone know what the fix is for a Security System Service Warning light.
Old Apr 21, 2025 | 10:28 AM
laserdude2215's Avatar
laserdude2215
You need to use a scan tool/code reader. Post the resulting DTCs for meaningful guesses.
Old Apr 21, 2025 | 10:32 AM
wolfganggardner
Got it, Thanks
Old Apr 21, 2025 | 11:30 AM
A local auto parts store may have a scanner that can give you the DTCs. If not, a dealer certainly can diagnose it for you.
Old Apr 21, 2025 | 12:23 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
It's best to get your Corvette to a dealership, so they can scan for codes which will shed some light on why this alert has come on. If you need help connecting with your local Chevrolet dealership, feel free to email us at socialmedia@gm.com. Please include your Username and Forum title in the subject line if you do contact us.
Old Apr 21, 2025 | 01:18 PM
wolfganggardner
Thanks for the great advice all.
Old Apr 21, 2025 | 05:16 PM
bearone2's Avatar
bearone2
can you give a description of what you're asking about/experiencing??
Old Apr 23, 2025 | 09:06 AM
wolfganggardner
The info center reads "Service Theft System" There are no codes in the system.
Old Apr 23, 2025 | 09:37 AM
Macleod52's Avatar
Macleod52
Did you replace your windshield recently? That caused my car to set off that message. Dealer had to update the computers to fix it; however, there is a TSB relating to it where you don't have to update the modules. I can't find it so if anyone else is handy maybe they can post it.
Edit: I think i found the TSB https://static.nhtsa.gov/odi/tsbs/20...12260-9999.pdf
Old Apr 23, 2025 | 09:43 AM
wolfganggardner
Nothing replaced on the car. Looks like I will have to head for the dealer.
Old Apr 23, 2025 | 09:49 AM
Macleod52's Avatar
Macleod52
Someone suggested in another thread was to disconnect the battery for 15-30 minutes and see if that clears it. Also, make sure your battery is fully charged. Weak batteries can throw all sorts of codes. I'd do those as easy tests before spending money at the dealer.
Old Apr 23, 2025 | 09:55 AM
wolfganggardner
I will try disconnecting the battery tonight and let you know. I recently replaced the battery and had a problem with all systems not working due to the main power cable being mis-alligned. Maybe that set off the "service theft alarm. Thanks.
Old Apr 23, 2025 | 10:23 AM
Macleod52's Avatar
Macleod52
Quite possible. I'd also put it on a charger and make sure it's topped off and when you hook it back up make sure you ensure everything is seated properly and that little black wire isn't damaged.
Old Apr 23, 2025 | 10:50 AM
wolfganggardner
Ok, will do.
Old Apr 25, 2025 | 09:11 AM
wolfganggardner
Hi All,
I disconnected the battery and reconnected it. That dismissed the warning message. Problem fixed
Thanks for all your great help! It saved me a trip to the dealer.
Old Apr 25, 2025 | 10:48 AM
Flattman's Avatar
Flattman
It never ceases to amaze me how sensitive these cars are to voltage disruptions and the myriad of faults they can produce. Glad you received good advice and it worked out for you
Old Apr 26, 2025 | 06:14 PM
DoubleG's Avatar
DoubleG
Can you ever say anything other than "see your local dealer"????? Why post then
To Security system warning
