C7 shift pattern
Old Apr 29, 2025 | 05:06 PM
Z4toc7's Avatar
Z4toc7
3rd Gear
Default C7 shift pattern
Howdy,, when shifting from 1st to 2nd (manual 7 speed) should there be a slight dogleg type movement with the shifter to the left before moving it back to 2nd gear. I'm looking to buy a 2014 Z51 that has that shifting weirdness.
Old Apr 29, 2025 | 05:17 PM
RonC7's Avatar
RonC7
No, straight back from 1st. 2nd can be a bit hard to engage when cold - be firm with the shift.
The only forward / rear gate that does not line up straight is 7th to R.
The shifter may need adjusted or some other attention.
Ron
Old Apr 29, 2025 | 08:51 PM
Guard Dad's Avatar
Guard Dad
Are you experiencing the dreaded 1-4 skip shift?
Old Apr 29, 2025 | 11:46 PM
^ Well that may be the case. Otherwise, it should be a straight pull back to go from 1 to 2.
Old Apr 29, 2025 | 11:54 PM
rdbragg's Avatar
rdbragg
The shifter will self-center at the nuetral position to be between 3rd and 4th. If you dally as you shift from 1st to 2nd or fail to keep a little leftward pressure on the shifter as you make a slow shift, then it would be completely normal for you to have to dogleg the shifter back into alignment with 2nd gear gate. I would say absolutely normal and I have a Z51 7MT. Enjoy the row!!
Old Apr 30, 2025 | 12:27 AM
Avanti's Avatar
Avanti
Just drive it as if it were a sports car and skip-shift never rears its ugly head.
Old May 1, 2025 | 08:47 AM
CraigStu's Avatar
CraigStu
If it does turn out to be a skip-shift 'feature', that can be easily fixed for about $30.
C7 Corvette Skip Shift Eliminator CAGS - RPIDesigns.com
Old May 1, 2025 | 09:25 AM
calvins's Avatar
calvins
Oldtimer
The "Skip shift" has been reprogrammed OUT of my car or I would have gotten the CAGS! That "feature" SUX!!!! As for 1-2,
I typically don't use 2 when it's "cold" as it IS a PITA to get into. I use 1-3 a lot, but I'm not a "racer" so.....
When I shift, I never grab the shifter though, 1-2, hand goes at the top and just pull straight back, goes right in. I never grab te shifter, except maybe to go into reverse, I just push/pull with my palm <shrug>
Old May 1, 2025 | 08:30 PM
mbaessler's Avatar
mbaessler
Did the dealer reprogram the skip shift out of your car?
Old May 1, 2025 | 08:47 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I've never understood the angst when the 1-4 skip shift pops up on the display. It just reminds me to give it more throttle to get past 20 MPH before making the shift to 2nd. Sport Mode and my unicorn Borla 60547 X-pipe make it more fun.
Old May 2, 2025 | 10:02 AM
jwcfbd's Avatar
jwcfbd
I've done this a few times.
Old May 2, 2025 | 11:47 AM
calvins's Avatar
calvins
Oldtimer
I honestly don't know. The original purchaser had it done.
Old May 2, 2025 | 03:07 PM
Blackwater0323's Avatar
Blackwater0323
Turn it off along with DOD/AFM. MGW with Redline D4 is the hot lick for effortless shifting even when its cold.
Old May 2, 2025 | 03:13 PM
ren80's Avatar
ren80
I have a 2014 m7 i have best 1 to 2 shift action when i cup the shifter from the right side and maintain a light leftward pressure as im shifting into 2nd. Dont grab the shifter and pull on it like a st10.
Old May 2, 2025 | 07:01 PM
Bill Dearborn's Avatar
Bill Dearborn
Why bother? DOD on manual cars has to be turned on by the driver so there is no reason to program it out. Skip Shift only occurs between the speeds of 14 mph and 20 mph if the driver is light on the throttle, so it only forces a shift if they are driving behind a slow driver and aren't paying attention to what they are doing. If caught out with the shifter being moved toward 4th push forward into 3rd and then pull it to 2nd. This can be accomplished in the blink of an eye so nobody, but you know it happened. Why spend more than a penny to avoid things that you can avoid with no effort at all?
Bill
Old May 3, 2025 | 09:19 AM
88redconvert's Avatar
88redconvert
As rdbragg says, the shifter is centered on the 3-4 position. Anything else will require a little push to the left or right. I've driven older manual's ( 4 and 5 speeds) all my life and the 7 speed took me some getting used to.
To C7 shift pattern
