Since the forum has been killing it on helping get this car going, I figured I would hit y’all with the next problem. When you hit the button to turn car off, engine turns off but accessory stays on and I get a message that car is not in park. Cluster shows P. Thanks Michael
If you don't have a factory level or equivalent aftermarket scan tool to scan for trouble codes see if your friendly auto parts store can do this for you...it always helps to let us know your model year as a minimum.
I had this happen when I replaced the Shifter **** with a Carbon Fiber one. Boy, was I pissed!
Turns out if I banged the top of the shifter **** with a closed fist, the problem went away. After a couple of weeks, it stopped doing that I did not have to bang the shifter any more since!
