High Flow Cats or Cat Delete?
Old May 20, 2025 | 09:58 PM
deepsfoyrotcaf's Avatar
deepsfoyrotcaf
Default High Flow Cats or Cat Delete?
I'm thinking about putting this Hotlicks Exhaust mod on my C7, one of the requirements says that you need to have a cat delete on the car for it to work properly.
Problem is, I live in California, where smog checks are extremely strict.
Slight good news is, that it may possibly work with a high flow cat, but it will most likely just burn out in the end.
So should I just get a high flow cat and watch it burn out? Or should I get a cat delete and watch myself fail the smog check.
Old May 21, 2025 | 09:13 AM
96GS#007's Avatar
96GS#007
Doubt it works on newer Gen cars like the C7. As soon as you press the button I’d expect the PCM to generate error codes. In addition, the fuel pressures on a C7 are an order of magnitude higher than old fuel injected engines.
Bullet cats fail in CA as do no cats. With no cats you’ll get errors for the aft o2 sensors. Program the errors out and CA will fail you for a modified tune.
Old May 22, 2025 | 12:52 AM
Guard Dad's Avatar
Guard Dad
Is it really worth it? Failing smog is a pain in the ***, is it really worth the hassle?
Old May 22, 2025 | 04:54 PM
CraigStu's Avatar
CraigStu
I agree. Why in Cali would you want to mess w/ emissions equipment? 20-30HP? Louder exhaust? Not me.
Old May 23, 2025 | 06:32 AM
449er's Avatar
449er
CF Community Team
DON'T do a cat delete, your car will smell like rotten eggs anytime you sit in traffic or at idle....most "sport cats" are junk & not worth the price. Modern OEM catalytic converters are very efficient & a very minimal horsepower gain is achieved from removing them
Old May 23, 2025 | 10:36 AM
96GS#007's Avatar
96GS#007
OP wants to shoot flames out the exhaust Fast & Furious style, not make more power.
Old May 23, 2025 | 11:34 AM
speed4tu's Avatar
speed4tu
Deleting cats doesn't smell like a rotten egg. The rotten egg smell comes from having cats that are problematic.
That being said, OP seems like its going to be a pain to have a California registration and do fun stuff with the car. Maybe change the registration to another state and bypass all the dumb regulations.
Old May 23, 2025 | 12:23 PM
Leroyt10's Avatar
Leroyt10
High Flow Cats will also fail the visual inspection, which in turn could put you, after approved Cat repair, on the yearly inspection requirement.
Old May 25, 2025 | 08:26 AM
Dcasole's Avatar
Dcasole
Yes you are right , you wont smell like rotten eggs .... you will smell like you just got thru mowing the lawn with an old two stroke weed eater
Dave
Old May 25, 2025 | 08:48 AM
weathermaker's Avatar
weathermaker
I thought that in California if you alter anything on the engine or exhaust system, you fail.
Old May 25, 2025 | 09:43 AM
Dcasole's Avatar
Dcasole
Flames .... on a C7 .... really ????????? Next you will tell me you want a "POP" tune
Dave
Old May 25, 2025 | 05:53 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
I think CARB may be going the way of the Dodo bird.
To High Flow Cats or Cat Delete?
