Front bumper
Old May 26, 2025 | 11:55 PM
Galdameznev's Avatar
Galdameznev
Cruising
Default Front bumper
The bumper next to headlight dosent fully seed properly im not sure if a clip or bolt or screw is loose but other side does not do it only driver side what should i do?
File Type: mov
Old May 27, 2025 | 12:06 AM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
You need to remove the bumper cover. Easy to do. There are lots of You Tube videos. Then there is a bracket in that location that can be adjusted up or down with the two bolts attached to it. From your video it looks like the bracket is loose or the notch on the tab that goes in the bracket isn't holding tight.
Old May 27, 2025 | 12:14 AM
Galdameznev
Cruising
Excuse me for the dumb question but would that require me to remove the front bumper on it? Also can anything go wrong if i just leave it or will it just be a mild annoyance
Old May 27, 2025 | 12:51 AM
DrivesWithTwoFeet
Yes, the bumper needs to be removed. It should be fine to leave it as is if you don't mind the movement. Looks like there is plenty of room between the fender and bumper so rubbing should not be an issue.
Old May 27, 2025 | 02:40 AM
I don’t think it will hurt anything to leave it as is, but to fix it right I would agree that the front cover should be removed and then reattached properly.
To Front bumper
