New
Old May 31, 2025 | 02:44 PM
Jrhodes's Avatar
Jrhodes
Default New
Hello everyone I am new to the forums and also new to the corvette community, I recently purchased a 2018 c7 and I am loving it. I have a quick question, when between 1-2k rpm my car feels as if it is stuttering and I was wondering if a triple flush would fix this or maybe someone can explain to me what’s happening. Thanks guys, look forward to see you in the forum!
Old May 31, 2025 | 02:52 PM
Kel15's Avatar
Kel15
Welcome to the forums from Ontario, Canada , you have any history of the vehicle to share, mileage etc.
Old May 31, 2025 | 03:04 PM
Jrhodes's Avatar
Jrhodes
Thank you, the car currently has 39538 miles on it, the car was serviced regularly. This typically happens when I am at a cruising speeds 45+. Feels like either the engine or transmission isn’t smooth at all times, it’s not like the engine is having a hard time as it runs fine. I do know all fluids were just changed including the differential. Sorry it is hard to explain how it feels but stutter is the best word.
Old May 31, 2025 | 03:09 PM
Martini28's Avatar
Martini28
Is it possible that your cruising in economy mode and the AFM is actively changing to 4 cylinders?
Old May 31, 2025 | 03:11 PM
Jrhodes's Avatar
Jrhodes
The car stays in sport or tour, mostly sport. I plan on getting a range to install to disable the AFM as I hear this is a good thing to do.
Old May 31, 2025 | 03:20 PM
Martini28's Avatar
Martini28
Is your car a M7 or A8? If A8 i think your car will always activate the AFM in any mode except Track mode. Not 100% sure, but its definitely a good thing to use the Range device!
Old May 31, 2025 | 03:23 PM
Jrhodes's Avatar
Jrhodes
A8 and the AFM is only inactive when the car is put in M and use the paddle shifters.
Old May 31, 2025 | 08:35 PM
jjuliano's Avatar
jjuliano
Does the problem go away in manual mode?
Old May 31, 2025 | 09:37 PM
Jrhodes's Avatar
Jrhodes
I haven’t tried, I will try this next week as I am out of state.
Old May 31, 2025 | 09:46 PM
jwcfbd's Avatar
jwcfbd
here's a video I found where he talks about the fluid flush and how it seems to have fixed his car.
Old May 31, 2025 | 09:48 PM
If putting the car in manual mode and the problem persists, have it checked by a good tech. Could be a triple flush would solve the problem.
Old Jun 1, 2025 | 07:10 AM
449er's Avatar
449er
CF Community Team
It's possible that you need the triple flush, your local Chevy dealer can run a GMVIS report to see if the flush has been done or not
Old Jun 1, 2025 | 08:51 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I have a 2015 A8 and I have the same issue in normal drive mode, but never in the manual mode. I am taking mine in next week for the triple flush.
Old Jun 1, 2025 | 12:59 PM
Jrhodes's Avatar
Jrhodes
https://youtu.be/p46l9dNwoGY?si=5Y3HeJ2A1xsMaJMZ
thank you for this, I am working with the dealer to get this done.
Old Jun 1, 2025 | 01:00 PM
Jrhodes's Avatar
Jrhodes
let me know what you find bud, I am interested in seeing what your problem is.
Old Jun 1, 2025 | 01:24 PM
bearone2's Avatar
bearone2
welcome to the forum!!
To New
