2015 Corvette convertible
Old Jun 9, 2025 | 06:46 PM
BritGuyinFlorida's Avatar
BritGuyinFlorida
5th Gear
Default 2015 Corvette convertible
I recently swapped out my battery, since then I cannot operate the drivers window, it doesn't index when the door is opened or closed either!
I checked the charge on the battery.
I disconnected the battery for a couple of hrs .
I purchased a new window switch .
Any ideas?
Old Jun 9, 2025 | 06:53 PM
stevettec7's Avatar
stevettec7
Any ideas?
Could you have left that small wire that's part of the harness disconnected?
Old Jun 9, 2025 | 06:58 PM
BritGuyinFlorida
5th Gear
please be more specific
Old Jun 9, 2025 | 07:00 PM
BritGuyinFlorida
5th Gear
which small wire - everything else works 100%
Old Jun 9, 2025 | 07:57 PM
kodpkd's Avatar
kodpkd
The little black wire on the negative terminal.
Old Jun 9, 2025 | 09:42 PM
^ Please check that the black wire is attached - if not, connect it and see what happens.
Old Jun 10, 2025 | 09:51 AM
NerV's Avatar
NerV
3rd Gear
You have to do the relearn process for the windows. Takes less than a minute. I did a quick search and got this:
To relearn the power windows on a C7 Corvette, fully open and close each window multiple times, and then hold the switch in the up position for a few seconds. This will reset the window's position for the car's computer to remember.
Here's a more detailed breakdown:
  1. Initial Position: Ensure the window is fully open or closed.
  2. Switch Operation: Push and hold the switch in the up direction, allowing the window to close fully, then hold the switch in the up position for a few seconds.
  3. Repeat: Repeat this process for the other windows.
  4. Confirm: Open and close the window to confirm that the relearn process was successful.
Old Jun 10, 2025 | 11:25 AM
Zjoe6's Avatar
Zjoe6
^^^ Yep. Page 2-23 of 2015 owner manual.
To 2015 Corvette convertible
