C7 M7 owners
Old Jun 10, 2025 | 01:55 PM
Casper001's Avatar
Casper001
Default C7 M7 owners
Do you get an occasional squeal sound when shifting in lower gears? Mine was doing it periodically last year and I was told the clutch pilot bearing was the issue, so I had that replaced. It still makes the squealing sound on occasion but not nearly as often. I have a '19 Stingray with approx. 40,000 miles.
Any thoughts?
Old Jun 10, 2025 | 01:56 PM
Macleod52's Avatar
Macleod52
My '14 w/54k does not make any kind of noise when shifting.
Old Jun 10, 2025 | 02:14 PM
fuzzy03cls's Avatar
fuzzy03cls
My 2019 had the noise. Pronounced in 4th gear mostly. While in 3rd or 4th, press the clutch in & out. Do you hear the noise. I was told throw out bearing maybe, but I traded it before it could be diagnosed.
Old Jun 10, 2025 | 02:54 PM
Casper001's Avatar
Casper001
When mine makes the noise, it is usually in 1st or 2nd gear.
Old Jun 10, 2025 | 03:45 PM
calvins's Avatar
calvins
Oldtimer
I've had a '14 Premier M7 and now a '15 vert M7 and have never experienced what you're describing.
Old Jun 10, 2025 | 04:22 PM
rfh928's Avatar
rfh928
Any thoughts?
Never anything on my 2019 M7. My C3 used to eat throw out bearings...but my C5 M6 after 21 years never had a single clutch issue (or much of anything else).
Old Jun 10, 2025 | 06:20 PM
^&right's Avatar
^&right
'15 with an A&A, 46k miles, no noise.
Old Jun 10, 2025 | 07:26 PM
fumbling's Avatar
fumbling
Any thoughts?
Yes I occasionally hear a squeaky sound starting off from a stop in first gear. It happens intermittently, there would be many days without the noise then a day where I hear it a few times, then goes away for a while, then a day of hearing it again.
I posted about it here, is this what you are hearing? I haven’t done anyhing since it’s just intermittent at this time.
https://www.corvetteforum.com/forums...irst-gear.html
Old Jun 10, 2025 | 09:03 PM
cgladish's Avatar
cgladish
I've only had my C7 since January (also a PE, #099). Bought it with 29k miles, currently at 39k, I haven't heard a peep.
Old Jun 10, 2025 | 09:22 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I've had 3 C7's with manuals and none had this type of issue.
Old Jun 11, 2025 | 12:39 AM
Avanti's Avatar
Avanti
I've had an '18 since the fall of '17 and none of that.
Old Jun 11, 2025 | 06:03 AM
JK 23112's Avatar
JK 23112
I bought a 2017 Stingray M7 new and owned it 5 1/2 years. I never had a "squeak" from the clutch at all, but on a cold day it sometimes made a slight noise that came from the gearshift area when going from first to second gear. It disappeared after about a mile of driving.
Then again, I sold the car with around 16,000 miles in May of 2022. I didn't have enough miles on it for anything to go wrong. Best of luck to all of you C7 owners out there!!
Old Jun 12, 2025 | 04:27 PM
Jmhornz71's Avatar
Jmhornz71
I dont have any noise on my 2015 with 131k miles
Old Jun 12, 2025 | 05:05 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
2014 M7 Z51 with no noise.
To C7 M7 owners
