What happened?
Old Jul 4, 2025 | 05:55 AM
tmbozoki@gmail.com's Avatar
tmbozoki@gmail.com
Default What happened?
Just got my sticker and build sheet from the museum and low and behold my Z51 has no NPP list ed anywhere! No I'm confused cause I was under the illusion all Z51s got the NPP as standard equiment, no? Added sticker and build sheet.
Old Jul 4, 2025 | 06:00 AM
Catfish4818's Avatar
Catfish4818
What year is your car? As mentioned in the other thread, NPP was separate from Z51 for the 2014 model year.
If your car is a 2014, the original purchaser ordered Z51, but not NPP.
Old Jul 4, 2025 | 06:17 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
as mentioned already, the NPP was not standard on the 2014 so it would show on the window sticker. If you have the 2014 model year, pull the carpet back in the rear area and look at the sticker to see if it is listed there. If you have the 2015 or newer, the NPP was part of the Z51 package and I am not 100% sure, but it may not listed as it is already part of that package.
Old Jul 4, 2025 | 06:35 AM
Kel15's Avatar
Kel15
Correct, just looked at my sheet, it's not listed, but I have it.
Old Jul 4, 2025 | 06:50 AM
tmbozoki@gmail.com
That explains my confusion....bummer
tmbozoki@gmail.com
I'm unconfused now, thanks, but a bummer
Old Jul 4, 2025 | 07:03 AM
76-Vetteman's Avatar
76-Vetteman
Yep, my 2014 Z51 did not come standard with NPP.
While I don't have a window sticker from the museum; I've simply been too lazy to order one, my Monroney label shows there was an additional charge of $1,195 for NPP.
Old Jul 4, 2025 | 08:28 AM
RonC7's Avatar
RonC7
Several of us told you in your other thread that NPP (and Mag Ride) were optional in 2014 and that we had paid extra for them...
What happened? You made a bad assumption...
Ron
Old Jul 4, 2025 | 09:04 AM
kodpkd's Avatar
kodpkd
I have the NPP on my 2014. I like it open all the time. You don't have to worry, if and when, they are closed. I installed the cat less X-pipe and it still isn't that loud.
Old Jul 4, 2025 | 09:48 AM
tmbozoki@gmail.com
Ron
I'm getn old n forgetful
Old Jul 4, 2025 | 11:41 AM
Too bad your car does not have the NPP option, but nice ride nonetheless.
Old Jul 4, 2025 | 12:34 PM
Flattman's Avatar
Flattman
On a positive note, if you'd ever want an aftermarket axle-back exhaust the versions without NPP are much less expensive and fairly easy to find used. I sometimes wish I didn't have NPP because I already pulled the fuse to keep the valves open and I'd like a bit more of an aggressive exhaust note I could get with aftermarket.
Old Jul 4, 2025 | 05:26 PM
Allen650HP's Avatar
Allen650HP
My early production 2014- C7 - Z51 - M7 3LT car. Im assuming it was odered this way?
Old Jul 5, 2025 | 07:36 PM
bearone2's Avatar
bearone2
Old Jul 5, 2025 | 08:00 PM
JLSuperfly's Avatar
JLSuperfly
Originally Posted by bearone2
Is it just the lighting or the NPP have shinier tips?
Old Jul 5, 2025 | 08:27 PM
bearone2's Avatar
bearone2
it's more the size but yes, mine are shiny!!
To What happened?
