Shocks?
Old Jul 24, 2025 | 11:16 AM
C7nut's Avatar
C7nut
Default Shocks?
Can someone tell me are the C7 OEM non MRC shocks the same on the base and Z51? GM parts shows one number for both.
Where can I find the part number for the base corvette shocks?
Old Jul 24, 2025 | 12:26 PM
Zjoe6's Avatar
Zjoe6
Try this website. Put in your VIN.
https://www.gmparts.com/
Old Jul 24, 2025 | 01:08 PM
C7nut's Avatar
C7nut
Originally Posted by Zjoe6
Try this website. Put in your VIN.https://www.gmparts.com/.
I tried that sife. GM parts shows one shock for both models.
Old Jul 24, 2025 | 01:25 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Different shocks for base and Z51.
rockauto.com
Old Jul 24, 2025 | 02:38 PM
Zjoe6's Avatar
Zjoe6
Sure enough. Link is for a 2014.
https://www.rockauto.com/en/catalog/...k+/+strut,7556
Old Jul 24, 2025 | 09:06 PM
14point5's Avatar
14point5
Cruiser
Veteran: Marine Corps
2025 C7 of the Year Finalist - Modified
2024 C7 of the Year Finalist - Modified
I replaced the base shocks with non-magride Z51 shocks and they are definitely larger diameter.
Old Jul 25, 2025 | 08:40 AM
CraigStu's Avatar
CraigStu
The Z51 shocks are also firmer.
Old Jul 25, 2025 | 09:53 AM
Markmbaha1's Avatar
Markmbaha1
The cars with Mag Ride which is an additional $2,000 factory only (no retrofit) option above the Z51 performance package, have electronically controlled shocks. You can easily check, if you have a wire running to the top front shocks, you have mag ride. It's important to note again, Z51 Performance Package Eben on later C7's does not include mag ride. Mine does not. Without the Mag Ride shocks the Z51 package does include other suspension changes, I don't know if that includes shocks or not.
Old Jul 25, 2025 | 03:17 PM
C7nut's Avatar
C7nut
I am only looking to find the part number for the base OEM shocks front and rear.
Old Jul 25, 2025 | 03:21 PM
C7nut's Avatar
C7nut
I am just looking to find the part numbers for the base C7 OEM shocks front and rear. Anyone know?
Old Jul 25, 2025 | 08:31 PM
DrivesWithTwoFeet
Old Jul 25, 2025 | 08:32 PM
DrivesWithTwoFeet
The part numbers are listed in the rockauto.com link above. GM Genuine Soft Ride shocks FE1.
To Shocks?
