Heating issue
Old Oct 8, 2025 | 02:14 PM
CraigStu's Avatar
CraigStu
Over many years and many cars this is the first time I have ever seen a car where engine temp is different than coolant temp. Do those come from different sensors, one in the engine and one in the coolant? Or are these actually the same temp from the same sensor that are labelled differently on the different displays? I see in the picture in post 12 that the digital and the analog are at about the same of 199deg. What is the analog gauge labeled as? I was going to look at mine but it is a 2019 so wouldn't necessarily the same as a 2014.
Old Oct 8, 2025 | 02:25 PM
kodpkd's Avatar
kodpkd
Only the 2014 have different, Engine and Coolant temps. The later years they are the same. I think it was an engineering thing on the 2014. Someone thought it would be a good idea to make the engine temp different. There isn't a different sensor, but the reading coming from the sensor, goes through the ECU, then to the two readings. I unhooked the sensor wire and both temp readings went blank. There is a different oil temp sensor, of course.
Old Oct 9, 2025 | 10:48 AM
bearone2's Avatar
bearone2
which sensor wire, can you post a pic please??
Old Oct 9, 2025 | 10:52 AM
kodpkd's Avatar
kodpkd
This is the location of the coolant sensor, only on the 2014.
Old Oct 9, 2025 | 11:02 AM
bearone2's Avatar
bearone2
that's the one i thought, thank you!! mine's also a 2014!!
Old Oct 9, 2025 | 05:08 PM
cgladish's Avatar
cgladish
The reading of the analog gauge is 220° (not 200°), vs 199° on the digital one. I know that the ECT supplies a reading to the analog gauge (I disconnected it once, and had no reading was displayed on analog gauge). I've seen people post that the analog gauge reads engine temp (not coolant temp). I'm still having a hard with this in that, no other gauges give a reading anything near 220° (coolant or oil).
Old Oct 11, 2025 | 01:49 PM
DoubleG's Avatar
DoubleG
This has been discussed many times. I has been agreed upon, I think, that the 2014 analog gauge is a general "I'm working gauge". It isn't exact at all. Most everyone with a 2014 has it sitting about 220. The disagreement is with the digital gauge. My digital reading will go up to 206ish, then immediately drop. This cycle slowly repeats as the thermostat does it's job. This means it's reading my COOLANT. Therefore, I say it's showing me my coolant temp. Why they labeled it "Engine" temp, nobody knows and unless we get an original GM engineer on her to tell us the facts, we will never know. And as was posted here, the sensor is embedded in the coolant flow. According to kodpkd, this sensor is for both the analog and digital gauges. That must mean that the ECU is programmed to give a "general" output to the analog compared to the digital. By default, that logically means the car engineers meant for the digital gauge to be the reliable reading of the COOLANT. At any rate and regardless of what is correct, those with a 2014 have only one source to look at for coolant temp, and that is the digital gauge. There is no other gauge.
I also think it was your t-stat. Trapped air would have had an immediate effect.
Old Oct 11, 2025 | 03:41 PM
cgladish's Avatar
cgladish
I do agree with you regarding this being an ongoing discussion. After all of this discussion, the only logic I can come with on the analog gauge reading is, that the analog (2014) is designed to be read like an old school idiot light. If you see a constant 220°, then you feel everything is fine. And until / unless something changes all is good. When in actuality, the coolant temp is never constant. Regarding the probable thermostat failure, if this is correct (and does appear to be so), this would be #2 since January. Maybe I should keep an extra one on hand. A 10mm wrench/socket and pliers and our set.
Old Oct 11, 2025 | 04:29 PM
kodpkd's Avatar
kodpkd
I purchased a laser thermometer. I tested the thermostat housing as it was warming up, when the coolant gauge was below the magic 220*. As the temp got to 220* I tested the housing again, it was a bit below 220*, went for a drive, Tested again, it was still just a bit below 220*, drove it a little harder and checked again, it was still just a bit under 220*.
Old Oct 11, 2025 | 04:56 PM
96GS#007's Avatar
96GS#007
Entertaining for sure.
File Type: pdf
Old Oct 11, 2025 | 05:05 PM
bearone2's Avatar
bearone2
thank you!!
Old Oct 11, 2025 | 05:16 PM
DoubleG's Avatar
DoubleG
Thank you so much for the bulletin. I will say my temps never converge, but oh well. NOW we can finally put to rest what the digital gauge is reading. As GM says in its own bulletin, the gauge is called the "digital engine COOLANT temperature gauge". The digital gauge IS the coolant temperature, not some vague "engine" temp.
CGLADISH...stats can go bad in a few months. I've had one be bad out of the box. Most of the time we get good ones, but yours going bad after 10 months isn't unheard of.
Old Oct 11, 2025 | 07:09 PM
  #33
bearone2's Avatar
bearone2
maybe now this one can be put to bed!!
Old Oct 12, 2025 | 11:03 AM
  #34
cgladish's Avatar
cgladish
Nice! This is the missing of the puzzle for me. I've heard from other posts something along the lines, but this addresses the issue directly (at least for me).
Thx!
Old Oct 12, 2025 | 11:09 AM
  #35
cgladish's Avatar
cgladish
I understand something going bad prematurely, it's just when it happens several times relatively close, is when I'm a little surprised. As I mentioned already, this is the first time in 46 years for driving that I've had a thermostat got (let alone 2 in 10 months). Has the quality gone down that much or, it is a C7 issue?
