Corsa systems
Old Oct 9, 2025 | 08:38 AM
smitty2919's Avatar
smitty2919
Default Corsa systems
Thinking of changing the exhaust on my 2019 GS manual and wondering why there are two different valved systems offered from Corsa. One has the over axle pipes and one does not for a $560 difference.
I do not have the AFM valves. Seems logical you can save $560 and get the cheaper system??
https://www.corsaperformance.com/pro...-w-factory-npp
I know it says auto with NPP and manual with NPP version, but a manual with NPP is the same system as the auto just without AFM valves.
Old Oct 9, 2025 | 09:54 AM
kodpkd's Avatar
kodpkd
Does you car have V4 mode in eco? If it does, it has AFM valves.
Old Oct 9, 2025 | 10:24 AM
smitty2919's Avatar
smitty2919
Yes I have eco mode and is a manual. My car does not have AFM valves.
Old Oct 9, 2025 | 10:28 AM
kodpkd's Avatar
kodpkd
BUT,,,, does your car go into V4 mode when you are in eco mode? The NPP valves have nothing to do with AFM valves.
Old Oct 9, 2025 | 10:45 AM
smitty2919's Avatar
smitty2919
Maybe? Regardless, I don't have AFM valves.
Old Oct 9, 2025 | 10:48 AM
kodpkd's Avatar
kodpkd
Did someone remove the AFM valves? Are you looking into the rear of the exhaust and don't have the valves?
Old Oct 9, 2025 | 10:52 AM
smitty2919's Avatar
smitty2919
I think you are confusing AFM valves and NPP valves.
The valves you see in the tips are the NPP valves. AFM valves are further up where you can't see them.
Old Oct 9, 2025 | 10:57 AM
kodpkd's Avatar
kodpkd
If you have V4 mode, you have AFM valves unless someone has removed them. I know where the NPP valves and AFM valves are.
Is your car a ZR1? The ZR1 is the only C7 that does not have AFM valves.
Removing these valves will set off engine codes and check engine light.
Old Oct 9, 2025 | 11:25 AM
smitty2919's Avatar
smitty2919
2019 GS manual I bought with 8000 mi and a non-modified exhaust. I DO NOT have AFM valves and whether my car does V4 mode in eco is a moot point lol
https://www.corvetteforum.com/forums...fm-valves.html
2017 and up the AFM valves were removed in Z51/GS/Z M7s. They were retained in the A8s.
Old Oct 9, 2025 | 11:55 AM
kodpkd's Avatar
kodpkd
Maybe this will help you.
Old Oct 9, 2025 | 12:03 PM
smitty2919's Avatar
smitty2919
Or let me further clarify, yes I have AFM engine feature....I do not have AFM VALVES. Maybe this has been the confusion.
Anyways, I just said screw it and called Corsa, you can use the cheaper 14776 system to save some money.
Old Oct 9, 2025 | 12:06 PM
kodpkd's Avatar
kodpkd
Let us know how it goes.
https://parts.gmparts.com/product/gm...16983%2C184295
Old Oct 9, 2025 | 12:11 PM
C6Goyo's Avatar
C6Goyo
@smitty2919 but do you have AFM? LOL (Joking) Looks like the GS M7 ones have more piping on the back of the mufflers, probably a fitment issue if you go with the less expensive ones. but id reach out to corsa to confirm
Old Oct 9, 2025 | 01:36 PM
Flattman's Avatar
Flattman
No AFM valves in the exhaust of all C7 Grand Sports, Z06's or ZR1's. Only us lowly Stingray folks get those.
Old Oct 9, 2025 | 01:43 PM
kodpkd's Avatar
kodpkd
WOW! You are correct, I am wrong. I don't know why there is so much contradicting info out there. I found where GM removed just the valves on the 2017 Manual cars and newer but still kept the AFM. Beer is on me!
Old Oct 10, 2025 | 07:45 AM
smitty2919's Avatar
smitty2919
Corsa said the muffler PN's in their BOM are the same between the systems and should work. I'm not sure I'm 100% on that given the price tag lol
Wishful thinking??
Old Oct 10, 2025 | 09:51 AM
Corsa makes a great exhaust system, and I would bet you’ll love the exhaust, but that is a heck of a difference in price between the two versions.
Old Oct 10, 2025 | 01:56 PM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
If you have a manual grand sport then you don't need the AFM valves, auto grand sport yes.
You would have to cut and clamp/weld on your stock exhaust over pipes to the Corsa one, the other one is straight bolt on.
We have both in stock and can help you answer any questions.
-Josh
To Corsa systems
