Lost a key fob $$$$
Old Oct 22, 2025 | 11:28 AM
aklim's Avatar
aklim
Originally Posted by 12yrs LATE
aklim:
Answer: yep, pretty much...one we think went out in trash after cleaning a counter top - the other lost two weeks later....totally unknown-therefore GONE
Wow. I thought you lost both keys at once. I was nervous when I got the C7 and discovered one key was not working. Quickly filed a claim and got another.
Old Oct 22, 2025 | 06:14 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Whenever we buy a new car (not very often), we bite the bullet and buy a third fob immediately.
On our C7, the third fob is wrapped in aluminum foil and hidden deeply inside the car. The key is hidden someplace outside, hidden well enough that even the Tech can't find it.
Old Oct 22, 2025 | 06:24 PM
JLSuperfly's Avatar
JLSuperfly
I assume the aluminum foil prevents it from sending a signal. No?
Old Oct 22, 2025 | 06:58 PM
bearone2's Avatar
bearone2
easy to get to if needed??
Old Oct 23, 2025 | 10:00 AM
Gearhead Jim
St. Jude Donor '13
Correct, and I've tested it multiple times to be sure. Re-wrap and test again after replacing the fob battery every few years.
Well, "easy" is a relative term.
No tools needed. I could tell you where mine is located, but then I'd have to ...
Old Oct 23, 2025 | 12:07 PM
bearone2's Avatar
bearone2
understood, sounds like a good idea but might be a nice tip for others!!
Old Oct 23, 2025 | 12:16 PM
88redconvert's Avatar
88redconvert
Do you hide the FOB key or did you have another one made?
Old Oct 23, 2025 | 01:04 PM
Gearhead Jim
St. Jude Donor '13
I hide the key from the fob on the outside, then wrap the fob (without key) in several layers of aluminum foil and hide it deeply inside the car.
We've done that on each of our four new Corvettes over the decades, and it has a great preventive effect- we've never needed the "Emergency" key.
Sometimes I'm a little disappointed about that, but happy.
Old Oct 23, 2025 | 02:02 PM
bearone2's Avatar
bearone2
thanks!!
Old Oct 24, 2025 | 03:13 PM
maddog11's Avatar
maddog11
aklim:
Put your key Fob on a bright color lanyard to minimize the chance you'll lose or misplace it.
Also, keep that fob in a Faraday pouch. Both the pouch and lanyard should prevent loss.
If you need extra loss protection, put an Apple Air Tag on the faraday pouch.
Old Oct 24, 2025 | 11:22 PM
aklim's Avatar
aklim
Got THIS. One pink and one blue so nobody gets confused who's key it is which affects the memory settings.
And also prevent it from being used. That means you get to fumble in your pocket for the key. If I see a situation I want to get away from fast, no way do I want to fumble for the pouch, get the key out to get the door unlocked and then get to drive away.
Old Oct 26, 2025 | 05:58 PM
bearone2's Avatar
bearone2
"looks different, but it works", for $360??
i'd rather buying from the dealer so all functions really work by vin, remote start, open back deck, vert top!!
