Thermostat replacement
Old Nov 3, 2025 | 12:07 PM
Corvette Kev's Avatar
Corvette Kev
Default Thermostat replacement
My car has been diagnosed with a bad thermostat, the replacement looks pretty simple. Has anyone done this and is it as easy as it looks?
Thanks,
Old Nov 3, 2025 | 12:13 PM
kodpkd's Avatar
kodpkd
Easy. Purchase the entire housing. Make SURE you get the correct temp rating! So many non OEM temp ratings. While you are in there, replace the temp sensor also.
Old Nov 3, 2025 | 03:35 PM
cgladish's Avatar
cgladish
It is pretty easy. I've got it down now, as I've replaced two this year alone. As noted, doing the ECT sensor is not a bad idea either. Even easier than the thermostat.
Old Nov 3, 2025 | 05:11 PM
Corvette Kev
Thanks for the quick responses. I have the thermostat, I'll look into the sensor.
Old Nov 3, 2025 | 10:29 PM
Skid Row Joe's Avatar
Skid Row Joe
The easiest R&R on a C7.....
Thanks,
Old Nov 4, 2025 | 01:10 AM
Midnight_rider's Avatar
Midnight_rider
Thanks,
Get you a billet thermostat housing while you're doing the change. I did it like 2 months ago. I got the DMS Billet Thermostat Housing with 160 Degree Thermostat - it was 174 degrees Choose Alternative Thermostat Temperature:174 Degree (+$4)
It's nice for when you have an intake and it's pointed the way you want. I paid
$240.91shipped.
Old Nov 4, 2025 | 06:13 AM
M61A1MECH's Avatar
M61A1MECH
Active Streak: 90 Days
Thanks,
Simple job, takes about 45 minutes, here is a link to the discussion that followed after I asked the same question.
https://www.corvetteforum.com/forums...s-done-it.html
Old Nov 4, 2025 | 09:57 AM
bearone2's Avatar
bearone2
several "how to" posts if you search!!
Old Nov 5, 2025 | 01:32 PM
MacklinUSOB's Avatar
MacklinUSOB
All that you need is a 10mm wrench and some pliers to relieve the hose clamps. If it is fully cooled off, you won't even need to add coolant. Doesn't get easier! Got the full tstat housing as well as the temp sensor from NAPA locally for about 100$. It's a luxury having parts available locally, after years in Euro cars, I never was so lucky.
Old Nov 6, 2025 | 07:52 AM
Tinkertech's Avatar
Tinkertech
Only use OEM parts.
Old Nov 6, 2025 | 11:17 AM
TxLefty's Avatar
TxLefty
Originally Posted by Tinkertech
Only use OEM parts.
Good idea if your original was a 194*.
To Thermostat replacement
