A/C Issues, compressor?
Old Nov 5, 2025 | 02:25 PM
DavidTheGawf's Avatar
DavidTheGawf
7th Gear
Default A/C Issues, compressor?
I’m having issues with my 2017 grand sport’s A/C. The A/C just started blowing warm one day after work. It has been 4 days since then, so not an intermittent issue. I have noticed that the compressor is not being engaged after popping the hood. Anybody else have this issue, and what was the final outcome for you?
Old Nov 5, 2025 | 03:09 PM
Flame Red's Avatar
Flame Red
If the AC is low on Freon, the compressor will not run at all. Get it to a good AC shop and have it checked. Maybe something a lot less expensive!
Old Nov 6, 2025 | 07:51 AM
Tinkertech's Avatar
Tinkertech
Check fuse and relay for power.
Check for power at AC clutch.
Check its ground.
Old Nov 6, 2025 | 12:51 PM
Jmhornz71's Avatar
Jmhornz71
When I had the problem with my 2015 it was the compressor replaced it Over$1200 later good as new
Old Nov 7, 2025 | 09:34 PM
PicaVette's Avatar
PicaVette
Check the relay too... had that issue before in other car
Old Nov 8, 2025 | 08:31 AM
ZO6LIFE's Avatar
ZO6LIFE
If it's low, you got a leak. Good luck.
To A/C Issues, compressor?
