LED Side Markers
Old Nov 18, 2025 | 09:43 PM
bartsky's Avatar
bartsky
Default LED Side Markers
Do any of these fit properly and not cause FM or TPMS issues?
Thanks!
Old Nov 18, 2025 | 10:12 PM
stevettec7's Avatar
stevettec7
One brand I can vouch for is made by Oracle Lighting. When I went cheap with some Amazon versions, I got random front/right TPMS failures/loss of connection.
Old Nov 19, 2025 | 12:01 AM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Old Nov 19, 2025 | 07:07 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
Oracles. Don't sit exactly flush (oh well) and work fine without issue for the past 6 years on my C7.
I had tried the "others", and they did set off the TPMS light.
Old Nov 19, 2025 | 09:01 AM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
Morimoto is another "name brand" you could try.
Old Nov 19, 2025 | 09:17 AM
kodpkd's Avatar
kodpkd
I have the $40 Amazon ones. They have never set off the TPMS light. They are not totally flush but you really don't notice. I like the look of black when off, bright when on. I also changed the rear reflectors to LED brake lights, same thing, black when off bright when on. The Oracle ones don't fit flush either, they have plugin issues and latching issues. I wonder if it's the same manufacture that makes both of them.
Old Nov 19, 2025 | 09:30 AM
oldercorvette's Avatar
oldercorvette
we have oracle and no problem!
Old Nov 19, 2025 | 11:16 AM
kodpkd's Avatar
kodpkd
They have fitment issues also.
Old Nov 19, 2025 | 04:40 PM
boraxman's Avatar
boraxman
Also have the Oracles - They work great but if you have OCD you should probably pass.
Old Nov 19, 2025 | 05:50 PM
frankbicknell's Avatar
frankbicknell
All of the types (from Amazon) I have tried worked OK and they fit flush. There was a problem with the leds on one set, but other than that no interference.
Old Nov 19, 2025 | 08:52 PM
Dcasole's Avatar
Dcasole
For those of you saying u had no issues , do u drive a lot at night ?
Dave
Old Nov 19, 2025 | 09:00 PM
Dcasole's Avatar
Dcasole
With couple of strategic placed 3m double face tape strips , my oracle's have fit perfectly for over 4 years
Dave
Old Nov 21, 2025 | 03:21 PM
shekmark427's Avatar
shekmark427
I went Oracle as well. Love them.
Old Nov 21, 2025 | 04:22 PM
bartsky's Avatar
bartsky
Thanks for the replies guys!
Old Nov 21, 2025 | 09:39 PM
frankbicknell
Dave
I drive at night, probably 70% day 30% night.
Old Nov 21, 2025 | 10:16 PM
The Oracle product does seem to have a much better track records of not interfering with the TPS system on the car. I run a set from JW Motorsports and they do occasionally set a warning about the right front sensor.
Old Nov 22, 2025 | 03:35 PM
mdolandese's Avatar
mdolandese
I also have the JW Motorsports as well and love them. They sit perfectly, very flush and no problems snapping into place. But also get the dreaded front right TPMS light. The Oracles are the only ones I ever heard of not throwing the light. I have the Oracles and I love them, just can’t get pass them not laying flush.( OCD flares up bad) I never had a problem with them staying on or had to modify to fit. Went in like butter just stuck out a little. Hers a pic of the Oracles.
To LED Side Markers
Old Nov 22, 2025 | 04:15 PM
Maxsuperdog's Avatar
Maxsuperdog
I run the Oracles with no issues. Just be aware that they are bright AF!
Old Nov 22, 2025 | 05:27 PM
Dcasole's Avatar
Dcasole
I tinted mine with dark window tint
Old Nov 22, 2025 | 05:38 PM
Dcasole's Avatar
Dcasole
See the pictures of mine that i posted above , a few well placed strips of 3m double face tape , some gentle massage with a heat gun on the retaining clips to make sure they all snapped in ... and now they are all flush ....and have been since I installed them a few years ago .
Should not have to do this with a $300 set of lights set of lights but I also understand manufacturing ... I am sure the bumpers are not held to any strict tolerances as far as depth as the OEM lights are a lot thinner with only having 2 leds where as the Oracle leds run the full length . I am sure that when they did their test fits, it they fit great in that one or two test mules....
Dave
