No blower
GOOD INFO:
Yes, dielectric grease is an insulator; it's a non-conductive silicone-based compound designed to protect electrical connections from moisture, dirt, and corrosion, preventing voltage leaks while allowing the actual metal-to-metal contact to carry the current once applied correctly. It should be applied to the outside of the connection (like inside a spark plug boot or on battery terminals after tightening) to seal, not between the mating metal surfaces where it could impede conductivity if applied too thickly.
That said, glad the OP got it fixed. I know the feeling and instead of driving it off a cliff, he had patience. Well done.
