Dead battery electrical issue please help!
Old Jan 2, 2026 | 02:41 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Default Dead battery electrical issue please help!
So I have a 2015 c7 z51. I went out to start it and car was dead. Nothing at all. Battery would not take a charge. Taking the battery out was a real pain but got it out and installed a new factory battery from Chevy dealer. Got lights in the trunk but that’s all. Door still won’t open but clicks if I try. Nothing at all on the dash. Nothing at all if I try to start it. Put my factory battery tender on and the new battery was only about half charged. Shouldn’t this be enough to get at least the door open? The other issue is that for some reason while changing the battery the drivers window went down and is now down with not enough juice to put it up. I hope someone can help please???
I also tried jumping it with the new battery in by using a 500 amp noco jump starter. Shouldn’t that have worked with a new battery?
Popular Reply
Jan 2, 2026, 07:17 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Default Fire’s out. Problem solved
So I went out to disconnect the negative cable because the “trunk” lights wouldn’t go out. I noticed the dreaded buss bar seemed slightly misaligned so I loosened it and straightened it out and was able to tighten it down farther. As soon as I did that everything started working as it should. She fired right up. Seems like everything has to go back perfectly on these bad boys. Changing a battery shouldn’t be that hard but I’m happy now. Thanks for your replies
Old Jan 2, 2026 | 02:50 PM
BELVIN20's Avatar
BELVIN20
Look at this battery change link, make sure all is tight, my first guess that is you may not have all the connections tight. If all is correct and tight, possible the 350 amp fuse is blown, but as in most cases in the C7 battery change, something is not tight. See link.
http://netwelding.com/Battery_Issues.pdf
Just a wild guess, but did you reconnect the thin black wire that goes on the battery?
Old Jan 2, 2026 | 02:57 PM
Ooze's Avatar
Ooze
If all the connections are good and you're still having an issue id take the battery back and have it tested and/or replaced.
Old Jan 2, 2026 | 03:46 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Default I might have messed up
So I appreciate the replies and quite possible that something isn’t aligned right or blown fuse. I guess I should have mentioned that while reattaching the negative cable my wrench accidentally touched the buss bar on the positive contraption. Would this have blown a fuse? It did spark. I don’t have the tools to test the fuses or the know how. Guess I should have had it towed to the dealer for the battery change but thought I could do it myself
Old Jan 2, 2026 | 03:50 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Default Something else
I also had a bear of a time getting the buss bar reattached. Couldn’t get the nut to thread. Was afraid of stripping it. Finally got it on but was difficult to tighten
Old Jan 2, 2026 | 05:57 PM
Let It Ride's Avatar
Let It Ride
Are you talking about the 13mm nut on the red cable? Because that is the only bus bar attachment point. The only other attachment points are the actual leads on the battery itself.
Old Jan 2, 2026 | 06:06 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Yes. The 13mm on the bus bar
Old Jan 2, 2026 | 07:16 PM
kodpkd's Avatar
kodpkd
There are a few good videos showing the correct battery install on the C7, really good info.
Old Jan 2, 2026 | 07:17 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Old Jan 2, 2026 | 07:54 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Glad you got it fixed. I’ve changed the battery in my ‘14 twice. It is a PITA. The battery in it now has a handle, making it MUCH easier.
Old Jan 2, 2026 | 08:25 PM
Doggydaddy's Avatar
Doggydaddy
Cruising
Thanks. Yeah this new one has a handle so next change should be easier
Old Jan 2, 2026 | 08:58 PM
Photomania's Avatar
Photomania
Do not beat yourself up. Many of us have had challenges during our first C7 battery swap. I know I did. For my first Stingray, I bought a NAPA branded battery. The battery was about a half inch or more shorter than the OEM. The car started well and ran well. But after work the next day, the car would not start and the entire dash went black and the car locked me in. I finally got out and I called my wife. She brought tools and I disconnected the battery for 20 or 30 minutes and put everything back on tighter. Drove the car for two more years and never had any issues.
I have replaced batteries in two Stingrays. About to do my third. I have noticed warnings on Diehard battery listings that say: Requires Professional Installation.
Old Jan 2, 2026 | 10:45 PM
Avanti's Avatar
Avanti
These batteries are notorious, especially the mess on top connected to the positive post.
Do an "Advanced search" across the C7 Forums and you will find many posts, including my own that discusses the problems that can arise (like yours) by needlessly disassembling the multi-piece pos. plate assembly (as almost all instructions everywhere say to do ). The gist of the fix if this is the problem is to make sure there is a good connection between those two pos. plates. The only way I could get this to happen was sanding both with 2000 grit sandpaper and cleaning with contact cleaner; plus "warping" them slightly so that when I reassembled them they would be pressed FIRMLY together. This was a couple years ago and it has worked flawlessly since. All the best.
Old Jan 2, 2026 | 11:02 PM
Steve_R's Avatar
Steve_R
I never disconnected the bus bar when I replaced the battery, just pulled the cables off the battery posts. There’s no reason to disconnect the bar to replace the battery.
Old Jan 3, 2026 | 06:11 AM
449er's Avatar
449er
CF Community Team
It sounds so simple but I read more than a few posts here about the car not starting after a battery replacement, always check ALL of the battery connections to make sure they are clean & tight & the new battery is completely charged
Old Jan 3, 2026 | 08:55 AM
Zjoe6's Avatar
Zjoe6
The trick is to hold that red cable end and twist it until the captured nut is perfectly parallel to the mating surface while starting the 13mm nut. It should thread on most of the way with very little effort. If that's not case, stop, start over. Twist the cable until that nut just threads right on. I only needed a wrench for the last turn at the most. And yes only detach the two battery posts, nothing else. You're just creating problems taking the other stuff apart. And the black wire should be inspected for a solid connection and proper routing. Don't pinch or pull on that connection. It has a routing from the factory that you should pay attention to before taking it apart. Take a picture.
The other thing many people screw up is the vent. Make sure to detach that elbow before removing the battery. Transfer the vent plug from the old battery to the new one. I believe there's a new plug on the new battery packaging but I didn't use it (never even saw it). I used the old one. Reconnect the old elbow and vent hose to the new battery. Make sure it's moved out of the way when lowering the new battery or it'll be hard to get at it.
To Dead battery electrical issue please help!
Old Jan 3, 2026 | 12:48 PM
orwollma's Avatar
orwollma
Old Jan 3, 2026 | 02:09 PM
kodpkd's Avatar
kodpkd
There are also torq spec's for the battery connections that are important to follow.
Old Jan 3, 2026 | 02:13 PM
633BR's Avatar
633BR
I almost missed that when I replaced mine, but yes the new AC Delco battery comes with the plug attached to the protective plastic cover.
