Hvac issue
Old Jan 3, 2026 | 01:42 AM
vette2284's Avatar
vette2284
Default Hvac issue
2015 ZO6. I only get airflow from ac vents. No flow to floor or defrost. While looking for scanner for abs bleeding i saw some scanners will move blend doors and activate actuators. Anyone know if this might resolve issues? Thx
Old Jan 3, 2026 | 07:20 AM
Dcasole's Avatar
Dcasole
I dont think it will resolve your issues but , it will point you in the right direction.... If you command each blend doors to move , and they do .... then the problem is with the control module, if they dont move then the problem is with the actuator
My money is on the actuators ... and they are a real pain in the butt to replace as the dashboard has to be disassembled
Good Luck , let us know what you find
Dave
Old Jan 3, 2026 | 08:16 AM
Good luck with the fix - hope it does not turn out to be a major disassembly project.
Old Jan 3, 2026 | 10:21 AM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Finally scheduled an appointment for Monday Jan 5 to have mine diagnosed for this same issue. Control module was replaced a couple years ago.
/JD
Old Jan 3, 2026 | 10:58 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
I had this same thing happen to me. The fix was a new blend door and actuator.
Old Jan 3, 2026 | 07:03 PM
vette2284's Avatar
vette2284
I was hoping for the best, but expecting the worst. I dont think I want to remove the dash myself
Old Jan 6, 2026 | 10:50 PM
jdaniels138
Below was the diagnosis for mine today, Jan 6, 2026:
Recalibrate HVAC actuators. Checked HVAC module for latest software. One hour labor.
Will update the post if the issue returns.
/JD
Old Jan 7, 2026 | 10:03 PM
jdaniels138
/JD
The recalibration did NOT last long. So took it back today for further analysis, Jan 7, 2026.
/JD
Old Jan 22, 2026 | 09:55 PM
jdaniels138
/JD
Picked up the car today (Jan 22, 2026) after about 2 weeks of waiting for the part to arrive, HVAC Control Module.
So the module was replaced and programmed. Fingers crossed that this is the fix.
/JD
Old Feb 2, 2026 | 09:39 PM
jdaniels138
/JD
Well back to the shop today (Feb 2, 2026), the problem came back. The service advisor confirmed related ODBII codes when I arrived.
/JD
Old Feb 2, 2026 | 11:58 PM
Amorget's Avatar
Amorget
Nice of the parts changers to lighten your wallet
Old Feb 3, 2026 | 07:17 PM
jdaniels138
They've been fair...
Credited my first service cost for the calibation that didn't work to the second.
And will credit the second service cost for replacing the control module to the work required to replace the actuators.
I also like that they didn't go straight to pulling the dash and replacing the actuators, they tried the least intrusive repairs first.
I've been going there since I bought the car and always see other Vettes there being serviced.
/JD
Old Feb 6, 2026 | 10:51 PM
jdaniels138
Got the car back today, Feb 6, 2026.
Will hold on declaring the issue resolved this time. The 4 actuators were replaced.
There is a rattle from the vent near the door on the passenger side. Pretty apparent and easy to reproduce.
Planning give them a call tomorrow to request for that to be checked and resolved. But will drive it for at least a week to make sure all is good before taking it back in.
/JD
Old Feb 8, 2026 | 09:44 AM
Tinkertech's Avatar
Tinkertech
They almost always fix one thing while breaking another. That's even if they guess right and actually fix the first thing.
I don't even trust them to wash my car.
That's why I do all my own work.
Note: I went bt a Lexus dealer and on their lot was a new LC500 convertible with a large sign on the windshield "DO NOT WASH" even though the car was very dirty. A very smart buyer knew better.
Old Feb 8, 2026 | 06:25 PM
jdaniels138
Found the source of that rattle while cleaning it up today: the plastic dash panel on the passenger side (the one visible when the door is open) was out of alignment. Tapping it reproduced the noise perfectly, so I repositioned it for now. I’ll likely pull it off later to apply some foam insulation tape to quiet it down permanently.
Im a DIY guy as well, but didn't want to tackle the A/C issue given all the posts I'd read about this issue. I've partially disabled the dash before on Honda's but not to the extent required to replace the blend door aquators.
/JD
Old Feb 14, 2026 | 04:43 PM
jdaniels138
/JD
All good after a week+, so declaring the issue resolved. No more rattling either.
/JD
Old Feb 15, 2026 | 07:15 PM
mkitt27's Avatar
mkitt27
Thank you for sharing - I will be dealing with this in the spring. Last fall started having issues with changing air flow modes. I could not change but they changed on their own a few times.
To Hvac issue
Old Feb 19, 2026 | 10:25 PM
PJ3400's Avatar
PJ3400
2nd Gear
Would you mind sharing how much the repair cost?
Old Feb 19, 2026 | 10:27 PM
jdaniels138
About $3,500.
/JD
Old Feb 19, 2026 | 11:51 PM
PJ3400's Avatar
PJ3400
2nd Gear
Yikes! Dealer? Fear I’m looking at the same thing…
