Air Conditioning Issues
Old Mar 11, 2026 | 03:29 PM
IAIA's Avatar
IAIA
Originally Posted by Tinkertech
When using a sniffer:
Also shows up at the vents when the fan is first started which blows it out from the evap chamber.
UV light is the easiest and cheapest way for most and a good starting point. Only shows up on the drain tube and not the vents. Also shows up at all the under hood AC components.
In the 'old' days we would just add a can of R12 and watch for the bubbles to disappear from the sight glass on the receiver.
Oh, the good old days! Have recharged many R12 systems back then.
So, from your post, are you saying the refrigerant can even show up from the air vent when the fan is first started, even if the evaporator coil is still good? When the guy sniffed the air vent and it detected refrigerant, he had just filled the system with refrigerant. There were no sniffed leaks under the hood, even underneath the car's engine compartment. Only from the air vents. I'm about to get a top-notch Chevy dealer who has experience yanking Corvette dashboards (when I went there a few weeks ago, they were yanking a C8 dash out due to needing an entire wiring harness replaced due to rodent damage), but I'm wanting to make sure before THEY diagnose it, whether there could be other sources of the leak.
Thanks.
Old Mar 11, 2026 | 06:22 PM
Tinkertech's Avatar
Tinkertech
Thanks.
The refrigerant is heavier than air. That’s why it first shows up at the drain tube, but it can also show up at the vents when you turn on the fan thus forcing the refrigerant out the vents.
The refrigerant if it is leaking from the evaporator core will not show up in the engine compartment, but will show up in that area at the drain tube itself
So when the technician monitored for a leakage of refrigerant at the vents, he was doing it correctly if he turned on the fan, but like I said, the refrigerant is heavier than air so it settles to the bottom of the fan box itself, and that’s where the drain tube is and that’s thus where you can monitor it from underneath the car
Usually, you cannot see the UV at the vent, but it should show up if it’s a major leakage at the drain tube
Old Mar 11, 2026 | 08:32 PM
aklim's Avatar
aklim
Thanks.
It sounds pedantic but the Chevy dealer isn't experienced at all. It is just a company that is doing automotive stuff. It is some of the techs who may be experienced in yanking a dashboard. This brings us to a "devil is in the details" thing. If you are like most car owners, they throw the keys on the table, expect that when they pick up the car, all is well when in reality, they got no clue as to who is doing what. I have had several appointment clerks that prefer I don't specify the mechanic so they can give my car to Mr. "Luck of the Draw". When they "hem and haw" about the specific person being busy, I usually tell them politely BUT firmly "Within reason, I am willing to wait for this guy.". For this kind of job, I suggest you really scope out the mechanic that is doing the job as opposed to them just assigning some guy who happens to be free at the moment.
Old Mar 12, 2026 | 08:27 AM
Tinkertech's Avatar
Tinkertech
Air conditioners are really simple to work on, except the evaporator because you need to pull the dash.
Most DIY's don't have the knowledge or the equipment $$$ to do it right.
Note: Your $20 Walmart can of refrigerant with the cheese dial ainta gonna work.
Old Mar 12, 2026 | 09:31 AM
aklim's Avatar
aklim
As a DIY person, I can't afford to buy the machine for a "one off", not to mention the tank of gas.
IMO, the can of refrigerant is a great thing to use to sell the car. For the buyer, not so much. For the mechanic to fix, it's good. I guess, as the song goes, "Two out of Three ain't bad".
Old Mar 15, 2026 | 09:25 AM
Tinkertech's Avatar
Tinkertech
You don't need the 'machine' that dealerships use.
All you need is all the separate pieces of equipment:
Set of good gauges with quality hoses.
Vacuum pump 1-5 CFM.
Leak detector, a quality one.
UV light.
Weight scale that can measure down to the tenth of an ounce.
DVM.
20Lb jug of the correct type of refrigerant.
An optical RPM gauge to measure fan speed.
And if your at the top of your game, a tank of nitrogen and an appropriate sniffer.
Don't forget the 'bubbles'.
I'm sure I've left something out but this is a good start!
Oh, I forgot the most important item, KNOWLEDGE. Without this one item you're never gonna make it, at least correctly.
Old Mar 15, 2026 | 10:03 AM
aklim's Avatar
aklim
UV light.
DVM.
And how much is that short list? They look like a lot of "one off" items.
Can the machine be rented instead of trying to get a bunch of pieces of equipment to work together?
Old Mar 16, 2026 | 09:29 AM
Tinkertech's Avatar
Tinkertech
I'm sure you could rent one but I never heard of this approach and I would expect it would be expensive. They're big and heavy, they won't fit inside the trunk of your Toyota. Also you would need a jug of refrigerant.
But then again, you would need the knowledge on troubleshooting and recharging AC systems or you're just wasting time and money.
My advice is find someone that knows what they're doing, a friend or repair shop, that is equipped to repair the system.
Old Apr 10, 2026 | 02:55 PM
IAIA's Avatar
IAIA
Almost in the shop. Diagnosed (2nd time...the shop would not do it unless they did hte diagnosis) and scheduled for dash R/R. $3000. SoCal.
Thanks for all the info.
