Battery Change Question
Old Feb 5, 2026 | 10:48 AM
Richard Ames's Avatar
Richard Ames
Default Battery Change Question
Seen a post about a memory saver 9 Volt and a plug to the rear tender plug.
The time is coming to replace the battery in my 2019 and two questions:
1. Does the memory saver work?
2: Can you use a battery tender instead?
Popular Reply
Feb 5, 2026, 12:03 PM
RonC7's Avatar
RonC7
You don't need a memory saver. Depending on how long it takes you to replace the battery you will need to index windows and possibly reset seat & mirror memory. It is a good time to review all settings in the infotainment system anyway.
BEFORE YOU START WITH THE BATTERY: test that the emergency key works to open the hatch / trunk and test the door manual releases. Leave at least one window open so you can reach a door release to get into the car.
Also a good time to replace the fob batteries.
A battery tender probably should not be plugged into the car without a battery present. I guess any 9 - 12 vdc battery connected into the rear accessory plug would maintain memory, but not worth the effort. If you do connect, be sure of the polarity.
Have Fun!
Ron
Old Feb 5, 2026 | 12:03 PM
RonC7's Avatar
RonC7
Have Fun!
Ron
Old Feb 5, 2026 | 12:12 PM
Blackcherry20's Avatar
Blackcherry20
I Love My C7
We didn't have to do anything when we changed mine.
Old Feb 5, 2026 | 03:55 PM
76-Vetteman's Avatar
76-Vetteman
Great advice from many above. Window re-index was the only task to do after my battery change. Everything else, memory seats/mirrors, etc., were just fine.
Old Feb 5, 2026 | 04:11 PM
rtv900's Avatar
rtv900
I didn't do anything at all when I changed mine
I didn't even know window indexing was a thing when changing the battery, of course maybe that explains why my windows don't go all the way up???
Old Feb 5, 2026 | 10:42 PM
That's all that was required when mine was changed.
Old Feb 6, 2026 | 08:33 AM
Zjoe6's Avatar
Zjoe6
I didn't lose anything when I changed my battery. I think I had to change the date and time and that was it.
Old Feb 6, 2026 | 08:52 AM
oldercorvette's Avatar
oldercorvette
no issue for us!
Old Feb 8, 2026 | 11:12 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
We'd like the opportunity to assist with your battery concerns and questions alongside your servicing dealership's support, Richard. To do so, may you please email us at socialmedia@gm.com with your VIN, full contact information (email address and phone number), mileage and the name/location of your servicing dealer? With that, be sure to include "Richard Ames/Forum" the subject line to best assist. We look forward to your outreach. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
Old Feb 14, 2026 | 09:19 AM
mdolandese's Avatar
mdolandese
No issues here when I changed out the battery. I believe just had to re index the windows to properly close
Old Feb 15, 2026 | 08:31 AM
NazTheGreek's Avatar
NazTheGreek
If it's the OEM battery, might want to invest in a lifting strap from Amazon or something. Nearly broke my back trying to get the OEM battery out. Ended up creating a handle with zip ties and fed them under the battery.
Old Feb 15, 2026 | 09:38 AM
kodpkd's Avatar
kodpkd
I just did mine. I didn't use any power to the system. Just in case, put the windows down. I also had to use a strap around the battery to get it out. A real pain in the butt. I got the ADCelco 48AGM for $177 at Walmart. Also, hard to squeeze in. You need to tilt it. Only remove the two main terminal connections and the large nut on the cable. I charged mine to full before I installed it. Don't forget to use the little red vent plug, that comes with the new battery, it plugs the hole opposite the original vent and install the original vent tube. DONT break the little black wires hooked to the negative terminal cable. DON'T tear the carpet.
Re-index the windows, set the clock, and you're done
Old Feb 15, 2026 | 11:01 AM
bearone2's Avatar
bearone2
i won't attempt to replace myself when time to replace '23 battery!!
Old Feb 15, 2026 | 07:51 PM
madrob2020's Avatar
madrob2020
Question? Will the 9 volt memory saver hold all the SMOG check info that is normally lost when battery is disconnected? All that info that has to be reset by doing multiple drive cycles. 🤔
To Battery Change Question
