It's going to be tough to ID just looking at it from the top as lots of aftermarket companies make copies of the factory splitter. Better to look on the bottom for a part number if it's a GM part.
I didn’t see any part numbers on it. So you know what usually comes on the base stingray? i will see if I can get a better picture. Looking on eBay the 1 seems to be a different shape than this one. Wondering if it’s a 2. Also does my one know if the 2 has mounting holes in the right place?
That appears to be a raw ABS aftermarket splitter, similar in shape and length to a Stage 2, which only came in clearcoated carbon fiber or painted Carbon Flash. I cannot identify that specific splitter as I've never seen one with such an aggressively defined center channel. None of the OEM splitters feature a center channel between the fangs like that.
OEM Stage 1 is a simple short lip, which does not follow the contours of the bumper "fangs" and is only as long as said fangs.
Stage 2 protrudes farther and does follow the contour of the bumper fangs like yours does, and comes with small winglets at the corners.
Stage 3 is a Stage 2 splitter with large winglets.
Can you provide a picture of the corners of your splitter?
[img alt="Here is a corner view of the splitter.
No, no bra the splitter is a flat black though. "]https://cimg7.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/img_1369_69075925f756e7622539a20f6eb943d d6ed4a4cf.jpeg[/img] Here is a corner view of the splitter. No, no bra the splitter is a flat black though. It also has the side spoilers too.
There are so many aftermarket splitters available it's nearly impossible to identify it with a couple of photos unless someone here happens to have the same one. Are you wanting to remove it, replace it, or something else?
That is 100% aftermarket. It's a "Stage 2" clone, and not an exact one at that. That's why it looks a big strange.
Yup. Google “corvette c7 splitter” and you get dozens of them, if not more. The one in the first pic looks like this one on eBay for $110. I’d be leery of the quality at that price.
I wanted to know which style so I could buy another if needed because I like the way this one looks. It is also made from fiberglass. Looks made pretty well.
That is a raw unpainted GTX Splitter with the detachable winglets originally sold by C7 Carbon.
