10w30
Old Apr 13, 2026 | 09:03 AM
Georgiaoldguy's Avatar
Georgiaoldguy
6th Gear
Default 10w30
I recently purchased a 2015 C7 with 32,000. After I purchased it I requested the inspection information that they had performed prior to sale. I noticed that they changed the oil and used 10W30. I reached out and the response was either 10W30 or 5W30 synthetic work. I feel more comfortable with the full synthetic. Is there any ramifications of switching it back to the full synthetic?
Popular Reply
Apr 13, 2026, 09:43 AM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
There are no ramifications from switching back to full synthetic. While GM "recommends" full synthetic, the requirement in your Owner's Manual is that the oil meet the dexos 1 standard. Far too many Corvette owners overthink oil, including type, viscosity, change interval, etc. Just read your Owner's Manual, do what it says, and enjoy your new C7.
Old Apr 13, 2026 | 09:11 AM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
5w30 or 0w40 full synthetic are appropriate use cases for the C7. I will personally be going with 0w40 for my next oil change.
Old Apr 13, 2026 | 09:20 AM
hiltsy855's Avatar
hiltsy855
Old Apr 13, 2026 | 09:29 AM
Macleod52's Avatar
Macleod52
I would switch to the recommended 5w30 or 0w40 full synthetic ASAP. Could you be fine w/the 10w30 possibly but why chance it? I'd say try to take it back to the place you bought it from and have them do it since it was their screw up but it sounds like they're incompetent so either do it yourself or take it to a reputable shop that will put the correct oil/filter in it.
Old Apr 13, 2026 | 09:43 AM
Steve_R's Avatar
Steve_R
Old Apr 13, 2026 | 09:54 AM
calvins's Avatar
calvins
Oldtimer
I run 0W40 full synthetic in my '15 Stingray - I see no issues with you switching back. The sooner the better!
Old Apr 13, 2026 | 05:12 PM
Bill Dearborn's Avatar
Bill Dearborn
Some 10W30 motor oils meet Dexos Requirements and may be acceptable. C7s can run a non-Dexos-rated oil, Mobil 1 15W50 oil, when on track. The downside of using it on the street is higher fuel consumption and a higher likelihood that the catalytic converters could be damaged. I used to leave the Mobil 1 15W50 in between track sessions since changing 10 qts of oil before and after a track event got expensive. The 0W40 Dexos-rated oil was developed for track/street usage.
Bill
Old Apr 13, 2026 | 05:45 PM
JLSuperfly's Avatar
JLSuperfly
My local dealer puts 5W-30 on my C7.
Old Apr 13, 2026 | 06:29 PM
oldercorvette's Avatar
oldercorvette
yes 5 w 30 !!
Old Apr 13, 2026 | 06:37 PM
TxLefty's Avatar
TxLefty
Based on the syntax, I think you said that they put 10W30 full synthetic in the car?
Old Apr 13, 2026 | 08:35 PM
kodpkd's Avatar
kodpkd
The latest, updated, recommendation from GM, oil for the C7 is the Mobil 1 0W-40 Supercar oil. There are many really cheap oils that many people use. It's up to you. You can always change the oil without any issues.
Old Apr 14, 2026 | 05:15 PM
DoubleG's Avatar
DoubleG
No ramifications
Old Apr 14, 2026 | 05:18 PM
Georgiaoldguy
6th Gear
That is also at question, it just said 10W30. Looking at the price it doesn’t seem like it was synthetic.
Old Apr 15, 2026 | 10:03 AM
TxLefty's Avatar
TxLefty
If you purchased at a dealer, I would take it back and request an oil change using a full synthetic 5W-30 or 0W-40 Dexos rated oil since that is the GM specification. Failing that, I would get the oil changed as soon as possible to one of the afore mentioned types. Filter change at the same time.
Old Apr 15, 2026 | 11:29 AM
CraigStu's Avatar
CraigStu
It is summer coming right up so I wouldn't be concerned about the 10-30. It would be nice to confirm exactly what make model/oil was used so you can decide on whether to leave it in there. But it's not like running even dyno oil for a few weeks or months is going to blow up the engine.
Old Apr 15, 2026 | 12:48 PM
TxLefty's Avatar
TxLefty
No, engine probably won't blow. But dyno oil is lot more susceptible to coking, which could cause some issues, particularly in the summer. Just me, but I wouldn't run it.
Old Apr 15, 2026 | 01:20 PM
I agree.
To 10w30
Old Apr 15, 2026 | 04:00 PM
rtv900's Avatar
rtv900
true, but coking is much more of a problem with turbo motors only because of the turbo oil supply and the blazing heat turbos see
in his case it shouldn't really matter that much, and the 10w-30 won't really matter as long as it's changed before winter (if he even drives in winter)
Old Apr 15, 2026 | 04:30 PM
Photomania's Avatar
Photomania
The C7 engine has tight tolerances and it was designed for full synthetic oil 5W 30. In addition, 0w40 is acceptable. If it was my C7, I would get that oil out as soon as possible. As long as I am able bodied enough, I will always change my own oil. I have had some bad experiences with dealerships letting their newbie mechanic change oil only to see that they overfilled it by over two quarts in my Honda 20 yrs ago. I personally know of a new mechanic who changed all the fluids in a customer‘s car only to forget to put oil back in the engine and then he started it up and it made a cluttering noise and a senior mechanic walked by and casually said: It will run better with oil in it.
Old Apr 16, 2026 | 01:46 AM
TxLefty's Avatar
TxLefty
Turbos are worse than non-turbos, but these engines have plenty of little passages where it expects a certain amount of oil to flow. It doesn't take a ton of contaminants to cause a problem, lifters, etc. Don't know his driving habits. He may be hammering it this summer. IMHO, putting the proper oil in the car is cheap insurance.
