Progress report Halltech's Stinger Intake system
Old Nov 7, 2013 | 09:50 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Progress report Halltech's Stinger Intake system
Update: Our complete carbon fiber intake will be finished Wednesday Dec 18th. We'll have pictures and videos then. The first system out will go to Katech for their chassis dyno testing having already completed the engine dyno testing +12BHP/+10lb-ft Torque SAE correction. +13/+10 STP correction. Texas Speed should have theirs shipping by Friday. The week after we are hoping to get our retail customer pre-orders shipped. The airbox will be fully enclosed, sealed to the fender exactly the way stock is set up. We are debating whether or not to keep the CKN Technology standard, or as an option to keep our pricing at $999.99 retail.
The one piece air box mold is finishing Weds or Thursday, two will be shipping to pre-paid dealers (Katech and Texas Speed), so by Friday or Saturday we expect 15 rwhp from their dyno testing. Our car will be chassis dyno tested as well. No tuning.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old Nov 7, 2013 | 12:38 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
When is this available? Id love to try one.
Old Nov 7, 2013 | 01:13 PM
genv6.2gm's Avatar
genv6.2gm
The mustang crowd has one that you can run without a tune, then there is a all out intake that requires a tune. if designing an intake to run one stock calibration holds back potential HP at even cam only levels perhaps you would make money on two models.
Old Nov 7, 2013 | 01:36 PM
Racer X's Avatar
Racer X
Originally Posted by 949 C7
Looks cool, but I have to think that if this thing costs more than $400 than it won't be worth it IMO.
I assume this intake will only translate into about 7-8 HP at the wheels, with a majority of that power coming from switching to K&N filtering element which lets too much dirt into the motor and uses oil to filter.
As for IATs, I don't see how going from a fully enclosed air box that the stock system uses to an exposed "heat shield" system is better. Unless it fully seals against the hood, there is a good chance the filter will pull air from the engine bay which is obviously not as efficient at the fully sealed stock air box which is a true cold air setup.
The stock systems tubes may run hotter than your carbon fiber and heat resistant coating, but air moves at such a high speed it barely has time to heat up before entering the motor. This is why the stock system is usually perfectly adequate in that regard. Now, with this intake, it can likely pull in hot engine air that is already heated and it doesn't matter if the plumbing blocks heat better than stock or not, since it is pulling hot air to begin with.
Not to mention the stock dry air filter is more efficient at keeping the dirt out of your motor.
I know you will have buyers for this thing and that is great, good for you - but I really am just trying to wrap my head around why in this case it would be a wise purchase for the C7.
Thank you
In the picture, it appears the filter is in the stock enclosed airbox, he says he is working on the heat shield which presume will enclose it in a way to allow it to pull from the same cold air source. He has been successful in designing good systems in the past. Also, as I understand it, he usually offers a dry filter as well as an oiled filter.
I would be stunned if Halltech does not also offer a rotomolded non-CF product as well that will be a bit less expensive than the CF version. I believe he has stated this in another thread.
The real comes when you add other power adders. The stock system flows well for the stock configuration. When you start flowing more air, then the limitations of the stock system show up.
Also a system like HallTech's sounds better. The stock system purposefully mutes intake noise.
Old Nov 7, 2013 | 08:05 PM
JMB's Avatar
JMB
Active Streak: 90 Days
It's too bad that you couldn't find an "out of the box" way to route the air from directly below the hood scoop rather than to the right so that you would have a soft transition/bend rather than the severe 90 degree tube like the OEM inlet......my personal experience on the dyno says that these sharp 90's kill torque and power (meaning that there is still more free TQ & HP just waiting even in your current configuration!).
Old Nov 7, 2013 | 10:08 PM
bglmn's Avatar
bglmn
I like what I hear. I'm excited. Halltech, headers, and tune will
equal 10's for sure!
Old Nov 24, 2013 | 10:02 PM
Phenox's Avatar
Phenox
any idea for a price for both units?
Old Nov 24, 2013 | 10:08 PM
kpgstingray's Avatar
kpgstingray
I am very interested in the roto-mold version of this system and seeing the before & after chassis dyno results.
Halltech - I know some aftermarket units have larger diameter intake pipes which can slow the air velocity down at lower RPMs, mostly noticeable when driving on the freeway in 5th/6th/7th gear under 2000 RPMs and accelerating at part throttle. The low end lags a bit but the tradeoff is more power above 2K RPMs. With your testing so far, has there been a loss of torque with this system below 2K RPMs? Dyno tests aside, I am talking seat of the pants feeling.
So far, your intake is on the top of the list for me so I really look forward to seeing the finished version.
Old Nov 25, 2013 | 11:29 AM
RedVett1's Avatar
RedVett1
Originally Posted by Halltech
Under $500 when we get the roto mold version done. The chassis dyno will be the same for both the carbon fiber version and roto mold version.
Katech is seeing +13/10 on the engine dyno.
Capacity will be around 1 per day in carbon fiber, so even if the price came in right, capacity will be too limited.
We have 5 on order, so that puts us around the first week of December.
Now snow. Hopefully we can get this done before major snowfall.
How do I get on the list for one?
Old Nov 27, 2013 | 05:30 PM
RedVett1's Avatar
RedVett1
Can you start a pre-order for the roto-mold option?
Old Nov 27, 2013 | 07:11 PM
RedVett1's Avatar
RedVett1
Your request is fullfilled. You will be first in and first out. #1.
https://www.halltechsystems.com/Prod...uctCode=HSTRRM
Awesome! Just placed my order, thank you!
Old Dec 3, 2013 | 11:25 PM
TrevorVette's Avatar
TrevorVette
8th Gear
Beautiful piece Halltech.
I am wondering, I am currently using the Pfadt tune which increased power and throttle response significantly for me.
If I add this intake, do you think it won't be a problem if I do not have a retune? There should be margins the PCM can play with in regards to the MAF sensor and adding fuel based on additional intake air flow correct?
I'd ask a tech at my dealership but they really know nothing about this type of thing.
Thank you
Old Dec 4, 2013 | 09:24 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
You would have to check with Pfadt. If they have not changed the MAF transfer curve, you should be ok. This intake is designed to change the air fuel ratio by about .3 without tuning, so it will go leaner.
The margins you refer to are closed loop stoichiometric re-trimming done automatically by the O2 sensor loop feedback. There are margins of +or-25%. The problem is open loop. The loop feedback is off during load or full throttle. That is where the unreported air might cause too lean conditions if there tune has already gone leaner to add power.
Jim
nice, they run around 12.4 commanded from the factory before COT... leaning it out to roughly 12.7 will pick up, they seem to make the best power around with the factory timing tables.
Old Dec 6, 2013 | 10:45 AM
Phenox's Avatar
Phenox
does this mean when you have your roto mold model in January will it also be an enclosed system like above?
Old Dec 6, 2013 | 02:36 PM
CNB's Avatar
CNB
Next year, we will have one ready to go for this motor:
What model is this engine going into? Details please!
Old Dec 6, 2013 | 06:09 PM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Default Halltech CKN Technology
All of our StingerCKN cold air intakes for the C7 are made entirely with our CKN technology. Carbon fiber outer and inner layers, with Kevlar, Nomex® III A sandwich meat.
Pending orders should start shipping December 18th. We have revised the heat shield to include a cover, for complete encapsulation.
The new mold will be finished next week, but PRI eats up the rest of the week.
We are now back-ordered through Christmas with pre-orders.
Old Dec 6, 2013 | 06:56 PM
drburns's Avatar
drburns
So then what were the final gains with this intake? If I understood correctly, you saw 10 or 12 hp on the engine dyno, which would translate to about 8 hp at the wheels. Awfully steep price for such a small gain. That being said, this is one of the nicest pieces of work I've seen for this or any car.
To Progress report Halltech's Stinger Intake system
Old Dec 6, 2013 | 07:35 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
this CAI is dead sexy!
Old Dec 8, 2013 | 01:55 PM
Phenox's Avatar
Phenox
where do the line that run over the intake go? i cant see them in the pictures
Old Dec 15, 2013 | 05:29 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
February or March 2014
