need help asap
Old Nov 26, 2013 | 02:17 PM
jwbert's Avatar
jwbert
Forgive the stupid question, but what does it mean to "flash the converter"?
Old Nov 26, 2013 | 04:05 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
In simple terms, I believe it's locking it (the trannys converter) up (pressing the brake and the gas pedal simultaneously), prior to launch.
Old Nov 27, 2013 | 05:14 PM
Jim Barker's Avatar
Jim Barker
Flashing the converter is no stall at all! the engine gets a jump on the converter action of locking in. This gives the best torque multiplication but not the fastest times. Its a combo of both until you blow the tires and go up in smoke. I had better recovery from tire spin with higher pressure in rear tires in my old pure stock days
Old Nov 28, 2013 | 12:13 AM
Snorman's Avatar
Snorman
Scraping the splitter.
St. Jude Donor '13-'14-'15
Flashing the convertor usually results in a higher rpm launch versus footbraking to the rated stall.
S.
