Digital Torque Wrench Special
Old Nov 27, 2013 | 01:33 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Default Digital Torque Wrench Special
Get a jump on your Holiday Shopping and get our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: vette
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until Dec 31st, and is only for the lower 48 states.
Old Nov 27, 2013 | 06:45 PM
CGZO6's Avatar
CGZO6
Do you have any plans to market one with a range less than 15 ft pounds/180 inch pounds?
Old Nov 27, 2013 | 11:32 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Have this one already. Great torque wrench. Just need a 3/8" drive in/lbs one now.
Old Dec 1, 2013 | 09:06 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Thanks. We are still working on the 3/8". We will let you know when it is ready.
BLMW
Old Dec 8, 2013 | 03:06 PM
Trackaholic's Avatar
Trackaholic
Took the plunge. Thanks for the discount code, and I'll try and provide a review after testing it out.
-T
Old Dec 17, 2013 | 06:25 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Need a torque wrench? Well here you go!!!!
Old Dec 20, 2013 | 01:41 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Don't miss out on a great wrench!!
Old Dec 20, 2013 | 01:57 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I've used one of these for years, never lost calibration. Excited to hear about a 3/8" version that would let me lose the adapter finally.
Would love to have one in a small inch/lb package for small bolts. Hey, let a guy dream.
Old Dec 20, 2013 | 04:07 PM
Motomike92's Avatar
Motomike92
Cruising
Trying to buy one but the code vette does not work.
Old Dec 20, 2013 | 04:18 PM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
You need to make sure the cart is empty, and then add the Wrench with Case version ($150). Then enter the discount code and the $99 price should appear.
Any trouble, you can PM me or call 312-884-7644.
BLMW
Old Dec 20, 2013 | 04:25 PM
Shaka's Avatar
Shaka
Expecting mine any moment.
Old Dec 20, 2013 | 04:43 PM
Motomike92's Avatar
Motomike92
Cruising
Ordered it! Had to use IE web browser. Go figure!
Old Dec 23, 2013 | 04:31 PM
Shaka's Avatar
Shaka
No batteries. Shucks.
Old Dec 23, 2013 | 04:58 PM
Theta's Avatar
Theta
I think it's 4 x AA if I remember correctly. Which reminds me, I need to replace mine.
Old Dec 31, 2013 | 08:47 AM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
Last Day!! Don't miss your chance!
Old Dec 31, 2013 | 11:08 AM
GWIZ06's Avatar
GWIZ06
Default Purchased today!
Hope it is as good as it looks.
Old Dec 31, 2013 | 12:05 PM
lgodom's Avatar
lgodom
Seems like a great deal. Just ordered one too!
To Digital Torque Wrench Special
Old Jan 3, 2014 | 11:21 AM
blmw's Avatar
0blmw
Former Vendor
St. Jude Donor '12
We had a few people tell us that they had trouble when trying to buy the wrench, so we are going to extend this for a few days. If you have any problems, email us at info@brownlinemetalworks.com and we will take care of it.
Thanks.
BLMW
Old Jan 10, 2014 | 09:43 PM
2MFFZo6's Avatar
2MFFZo6
How can I pass that up. Got mine
Old Jan 11, 2014 | 07:27 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Don't know if this deal is still on. The site wont take the discount code. Emailed vendor.
