Old Mar 5, 2015, 07:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
Rear Sway Bar Install
Old Jan 2, 2014 | 05:52 PM
Paleden's Avatar
Paleden
Default Rear Sway Bar Install
Purchasing non-Z51 car and want to install Z51 rear sway bar. Part is under $270. Dealer advises against stating that this would be an involved job with many parts to remove to place bar within sub-frame, etc. Does anyone have any experience with this? Want to achieve ride of non-Z51with a few suspension tweaks. Thanks
Old Jan 2, 2014 | 06:40 PM
C7pimp's Avatar
C7pimp
Take it to a performance place that has experience with corvettes. A sway bar installation is not that hard.
Old Jan 2, 2014 | 06:45 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I'd wager that if you find a Corvette shop, they'll charge $150-200 for the installation.
The front one is cake - I can't imagine the rear being much worse.
Old Jan 2, 2014 | 09:20 PM
Pat Salerno's Avatar
Pat Salerno
The dealer is blowing smoke. The install is very similar to the c5 or c6 rear sway bar install. However , if you don't install the front bar also, it will probably. Make it tail happy.
Old Jan 2, 2014 | 10:46 PM
runutzzzzz's Avatar
runutzzzzz
I'd say save your money, the base car handles just fine!
Old Jan 3, 2014 | 02:10 AM
C7pimp's Avatar
C7pimp
Correction, it handles amazing for a base car. Very impressive actually.
Old Jan 3, 2014 | 07:19 AM
Paleden's Avatar
Paleden
Thanks. Guess it makes sense to drive the car first and evaluate any further needs.
Old Jan 3, 2014 | 07:21 AM
Paleden's Avatar
Paleden
I wouldn't think so. Thanks
Old Jan 3, 2014 | 09:02 AM
VERBOTEN's Avatar
VERBOTEN
[QUOTE]However , if you don't install the front bar also, it will probably. Make it tail happy. /QUOTE]
Exactly. Stiffer rear bar is going to add oversteer.
Old Jan 3, 2014 | 11:06 PM
RapidC84B's Avatar
RapidC84B
You need the bar, bushings, brackets, bolts and endlinks... then just bolt it all in. Do the front bar or the car will be tail happy. Should probably drive the car before you start modding. GM engineers obviously found they could control roll sufficiently with the monoleaf out back.
Old Jan 3, 2014 | 11:08 PM
Theta's Avatar
Theta
The addition of the front/rear bars is really not necessary... This coming from a Z51 owner.
The base model drives like it has a traditional bar setup because of the design.
Just my opinion...
Old Jan 4, 2014 | 11:46 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Pfadt Engineering (a forum vendor) is in the suspension business and has a C7 for product engineering purposes. They could tell you exactly what parts are needed for what results.
Old Jan 4, 2014 | 02:34 PM
Theta's Avatar
Theta
Seconded.
Old Jan 4, 2014 | 11:03 PM
Ben@WeaponX's Avatar
Ben@WeaponX
St. Jude Donor '14
WCC makes an aftermarket sway kit too, same fits c6
Old Jan 11, 2014 | 10:54 PM
Turbooo2u's Avatar
Turbooo2u
Are you saying that C7 bars are interchangeable with C6 bars???
To Rear Sway Bar Install
