C7 performance brake pads including low dust
#1101
Supporting Vendor
St. Jude Donor '11,'13
Open Saturday for QUESTIONS and of course ORDERS... Give me a call at 216-780-8825.
If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
F: Base/Z51 CT1001
R:Base/Z51 CT1718
F: ZO6/GS Iron rotor CT1405
R: ZO6/GS Iron rotor Ct1718
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1102
Supporting Vendor
There is no Pre bed for the 1521 they do not require any bed in. The AX6 and XP series pre bed is $ $20.00 and axle set. So front and rear total would be $40.00.
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1104
Supporting Vendor
Carbotech performance brake pads including low dust performance street pads. 100% made in the USA!
Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
Street pad is the 1521 compound low dust 100% non-corrosive will not harm your wheels or paint.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1106
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1107
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1108
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct link: http://ampdautosport.com/
__________________
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1109
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1110
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1111
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1112
Supporting Vendor
Carbotech brake pads.... Street to Track WE HAVE THEM save $$.. Use promo code z28 at check out http://ampdautosport.com/brake-pads/corvette/ or call direct 216-780-8825 All major CC accepted... We can also send pay pal..
100% MADE IN THE USA
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1113
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1114
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1115
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1116
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1117
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1118
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1119
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1120
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
