C7 performance brake pads including low dust
#1141
Supporting Vendor
St. Jude Donor '11,'13
Use promo code z28 at check out and save $$ or call us direct at 216-780-8825 and save $$.
Street pad is the 1521 compound low dust 100% non-corrosive will not harm your wheels or paint.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
F: ZO6/GS Iron rotor CT1405
R: ZO6/GS Iron rotor Ct1718
http://ampdautosport.com/brake-pads/corvette/
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1142
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1143
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1144
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1145
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1146
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1147
Supporting Vendor
Open Saturday use promo code z28 at check out http://ampdautosport.com/brake-pads/corvette/ or call direct 216-780-8825 All major CC accepted... We can also send pay pal..
100% MADE IN THE USA
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1148
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1149
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1150
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1152
Supporting Vendor
Use promo code z28 at check out for your 5% discount. or call me direct at 216-780-8825 ZO6/GS part numbers.
F: CT1405
R: CT1718
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1153
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1154
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1155
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1156
Supporting Vendor
Open Saturday or order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%. If you do not know what you need call me at 216-780-8825 or email sales@ampdautosport.com
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1157
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1158
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1159
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#1160
Supporting Vendor
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Part numbers:
F: Base/Z51 CT1001
R:Base/Z51 CT1718
Order here.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
