P0697 error code limp mode trigered
Old Jan 13, 2014 | 08:33 PM
00hotvette's Avatar
00hotvette
Default P0697 error code limp mode trigered
I now have my car flashed back to stock and I'm pulling this code P0697 (sensor reference Voltage C circuit open). Is there a fuse for this? any help would be great.
Old Jan 13, 2014 | 08:50 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
That's an ECU 5v fault. Re-flash the stock tune file.
Old Jan 13, 2014 | 09:01 PM
00hotvette's Avatar
00hotvette
Wish I could. With the engine light she wont go into service mode.
Old Jan 13, 2014 | 09:46 PM
00hotvette's Avatar
00hotvette
Theta your the man of the year!!!!!! went down to the garage and was able to put her into service mode (the C7 has a mind of its own) re-flashed it back to stock on slow burn (it went fast) and no more codes so far. Has anyone else had this many problems flashing the C7?
Old Jan 13, 2014 | 10:08 PM
killascrimp's Avatar
killascrimp
I ran DS tune no probs so far...
Old Jan 13, 2014 | 10:11 PM
Theta's Avatar
Theta
It's temperamental for sure - discharging the ECU takes a bit of time in these (and many other new GM vehicles).
Once they're flashed entirely, you don't see this crop up. Even one little error in programming, though, can cause headaches like this.
USB communication is usually at fault for those instances. Remember to keep a good stock flash safe on a USB stick, Dropbox, etc. in case this every happens again!
To P0697 error code limp mode trigered
