First Halltech StingerCKN Intake on customers car PICS
Old 01-15-2014, 01:55 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Default First Halltech StingerCKN Intake on customers car PICS
Sent by a much better photographer than me: He installed the intake without our installation instructions, now available.
__________________
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
262-510-7600
For service email:
orders@halltechsystems.com
www.halltechsystems.com
Old 01-15-2014, 08:12 PM
VNAMVET
VNAMVET's Avatar
A cardiologist may be able to pay $$$$$ for it. What do you have available for us
retired folks....
Old 01-15-2014, 08:23 PM
Theta
Theta's Avatar
St. Jude Donor '14-'15
I believe the next non-CF variation is nearly complete. That version will cost significantly less from earlier indications.
Old 01-15-2014, 08:28 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
retired folks....
We are working on the roto version. Had a setback on our Rapid Prototype model cracking at the MAF mount. Hey, only $1200 for a new model.
As soon as we get our model complete, the mold will go into production.
We are looking at the end of Feb.
$499 retail.
Old 01-15-2014, 08:29 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Yep.
Old 01-15-2014, 08:37 PM
Z0Sick6
Z0Sick6's Avatar
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,568 Likes on 534 Posts
St. Jude Donor '05
any difference in gains with the CF and non CF intake?
Theta
Theta's Avatar
The CF may offer slightly cooler IATs from the material heat soak differences.
Old 01-15-2014, 08:56 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
We are going to use a special Nylon/Poly mix for better heat resistance, but nothing compares to Carbon Fiber, with Nomex III cloth as sandwich meat. Our IATs ran +3 to 4 Degrees F vs ambient for the entire trip from Wisconsin to Michigan. Typically, stock is +10 F vs. ambient.
That will not account for much horsepower (.5%), but we just got numbers in from Vengeance Racing tonight which will turn some heads. I will let Ron or Kevin announce them.
Other than the material, and slightly better IATs with the Nomex III, the power will be the same.
Old 01-16-2014, 02:36 AM
The running man
The running man's Avatar
That is one bad a$$ looking intake!
Old 01-16-2014, 11:14 AM
CNB
Support Corvetteforum!
CNB's Avatar
Very nice Jim! What are the results from Vengence? I haven't seen their post.
Old 01-16-2014, 11:48 AM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
I'll let them announce results after they retune it. Their car was fitting with a cam and headers, so our intake made a huge difference over the stock airplug, since the synergistic demand for more airflow was huge.
So far, we have seen three stock C7s gain 9 RWHP/6lb-ft, just simple bolt on results, with no tuning of any kind. Katech, Halltech, and Texas Speed.
Katech's C7 and our C7 went to 14 RWHP/9lb-ft with Katech's tuner just touching up the MAF tables only.
Katech did 555 HP (preliminary) on the engine dyno with our prototype intake, headers and their new cam. and will be retesting the production version soon.
Vengeance did better than we expected without retuning. Waiting for their final numbers.
Old 01-16-2014, 11:51 AM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
Default Backorders done
After 2 more Stingers shipping Monday to Geiger Cars in Germany, we are caught up on backorders.
Jim
Old 01-16-2014, 01:47 PM
deanm11
deanm11's Avatar
Default Dyno results with consistent A/F ratio?
Jim, The CF unit is gorgeous. I love your approach and products and plan to be a customer when I get a C7. I have a question about tested results. Now the results you cite are without a tune- which is great because tons of your customers will get exactly what was tested when they bolt on the product. Do you have any results you can share where the A/F is normalized/tuned with the intake to match the bone stock WOT A/F ? I just want to know if/what of the pickup is due to a slight lean-out of the A/F. That all said, I'd buy based on the heat soak prevention alone.
Old 01-16-2014, 05:53 PM
nickmenow
nickmenow's Avatar
Announced => http://forums.corvetteforum.com/c7-t...ts-inside.html
Old 01-16-2014, 06:38 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
The 14 RWHP is actually bringing back some of the leaning out; the opposite of what you might think.
We actually do not affect closed loop fuel trims differently than stock. MAF translation is perfect. Timing stays steady with our intake, with no knock retard at all even though open loop leans out slightly.
+9 to 10 RWHP can be taken to the bank on the stock motor, with no mods or tuning at all. Getting the air fuel ratio to best power through simple MAF correction methods puts down +14RWHP 9lb-ft.
Invite us to the party where Mr. headers and Mr. cam are dancing and we move onto the dance floor with +19 RWHP +21lbs ft. without retuning anything.
Old 01-16-2014, 06:47 PM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,093 Likes on 659 Posts
Very nice Jim, looks great.
Old 01-19-2014, 05:39 PM
drjim100
4th Gear
drjim100's Avatar
Default First customer install of CAI by Halltech
Just finished instillation of the CKN unit by Halltech and since I don't have access to a dyno for now I have to take their word for the gains. What I can attest to is that the unit is absolutely gorgeous and fit is first class. Did the instillation without instructions, that's how easy it was. By the time I rerouted the radiator overflow lines and installed the unit it took a little over an hour. Of course I also was enjoying a cigar and some scotch, negate the last two and instillation should be 30 minutes or so. Jim has already posted some of my pictures. I would highly recommend this beautiful and functional work of art. Halltech has been extremely supportive and without hesitation answered any and all my questions. I will do a tune as soon as I can. Any questions feel free to email me.
To First Halltech StingerCKN Intake on customers car PICS
Old 01-19-2014, 08:15 PM
Turbooo2u
Turbooo2u's Avatar
Hopefully a mail-order tune from a company like Pfadt can compensate for the new Halltech piece.
Old 01-19-2014, 11:05 PM
Halltech
Supporting Vendor
Halltech's Avatar
St. Jude Donor '09
It really needs no compensation. Last mod to the Vengeance party gained +19 RWHP +21lb-ft torque, without any change in programming:
Old 01-28-2014, 03:20 PM
leadville1
leadville1's Avatar
Didn't realize Haltech was in Wisconsin, I have a Z51 on order. I am looking to get max gains without touching the ECU to maintain the factory warranty, so headers and intake are on my short list. Is it your contention that the car adapts without software for better breathing on the intake and exhaust and doesn't go lean?
Quick Reply: First Halltech StingerCKN Intake on customers car PICS
