Upper Control Arm Torque Spec
Old Jan 31, 2014 | 02:58 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Default Upper Control Arm Torque Spec
Could anyone provide me with the bolt torque spec on the four upper control arm bolts?
I can't find a full torque sheet anywhere (as is expected), so pardon the ignorance.
Edit: Found the official spec sheet -- 48 ft/lbs.
Old Jan 31, 2014 | 06:12 PM
00hotvette's Avatar
00hotvette
Theta you must be installing Pfadt headers. *Upper control Arms 45 ft-lbs this is what they told me.
Old Jan 31, 2014 | 07:03 PM
Theta's Avatar
Theta
Thanks much. The joys of having a new model - no torque spec sheets.
Old Oct 12, 2016 | 06:13 PM
LsxFan1's Avatar
LsxFan1
Do you have to use any loctite on rear upper a arm bolts if you take it apart and put it back? Blue or Red?
To Upper Control Arm Torque Spec
