Header Install Question on Z51
Old Feb 23, 2014 | 12:09 PM
leadville1's Avatar
leadville1
Default Header Install Question on Z51
On the Z51 does a header install require removing the oil feeds from the sump? Just curious if you should wait for a break in period before installing them if your dumping your oil.
Old Feb 23, 2014 | 01:08 PM
00hotvette's Avatar
00hotvette
Yep and its not fun. Good luck hope they fit.
Old Feb 23, 2014 | 04:23 PM
Zmoy2's Avatar
Zmoy2
My ARH 1 3/4 did not require removal of the oil feed lines. They slipped right in.
Old Feb 23, 2014 | 06:25 PM
leadville1's Avatar
leadville1
Long tubes or Shorties?
Old Feb 23, 2014 | 08:01 PM
Zmoy2's Avatar
Zmoy2
Long tubes
Old Feb 23, 2014 | 10:38 PM
00hotvette's Avatar
00hotvette
You must have the header brand that requires you to drop your sub frame oil lines and front suspension. Been there done that.
To Header Install Question on Z51
