C7 Driver Information Centre - does it allow driver to delete error codes
Old Feb 25, 2014 | 10:46 PM
cebars's Avatar
cebars
Default C7 Driver Information Centre - does it allow driver to delete error codes
Does the C7 Driver Information Centre allow the driver to retrieve and erase error codes like the C5.....so I don't need to pay the dealer to clear a code....
http://forums.corvetteforum.com/c5-g...dic-codes.html
The "diagnostic display" mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" , press "fuel" four times within a 10-second period.
When first engaged the on-board diagnostics go into an "automatic" mode.
The computer will show two kinds of codes, "current" and "history," designated "C" or "H".
A current code indicates a malfunction is present in the system whose module is displaying data.
A history code indicates a past problem.
When the screen displays "manual diagnostics," select the desired module by pressing the "options" button
to go forward or the "trip" button to go back.
Press "gauges" to go forward or
"fuel" to go back for each code under a module.
Old Feb 25, 2014 | 11:17 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
No, which sucks, I loved that about my '03.
