How do I get wire thru firewall
Old Feb 28, 2014 | 10:43 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Default How do I get wire thru firewall
Hi, I am installing parking sensors on front and need to get wire into cabin. Does anyone know how to run wires thru firewall.
Thanks, George
Old Mar 1, 2014 | 04:51 AM
Supermassive's Avatar
Supermassive
I learned a long time ago that trying to get a wire through the wire loom pass thru's is an exercise in futility. I typically route any accessory wiring through the HVAC pass thrus. the rubber seals are easier to get the wire through and you can easily seal around the wire with silicone sealant or whatever you want to use.
Of course I don't have a C7 yet so there may be an easier routing method that i don't know about yet.
There is also the drill method where you go to an auto parts store pick up a rubber grommet for the wire you want to pass thru and drill a hole in the firewall in an inconspicuous spot and seal it. Not the easiest...and you have to drill so there's that.
Just my two cents.
Old Mar 1, 2014 | 04:30 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
George, I know I have a schematic here of the front wire harness routing. I'm looking through now to see if I can find where your driver's side grommet is.
I will post here as soon as I find that diagram.
Old Mar 1, 2014 | 04:37 PM
Theta's Avatar
Theta
This is not the exact schematic I was talking about, but I can't find that one at the moment.
There is a wire harness grommet that is deep up in the driver's footwell in the red zone. The green dot approximates the area.
I'm looking to see where that emerges from on the other side, and if it's easily accessible.
I will be working on my car today, so I'll let you know what I see from the engine compartment.
Old Mar 1, 2014 | 05:27 PM
slief's Avatar
slief
Theta, Like I told George in his other thread, remove the drivers side front wheel and either remove or peel back the fender liner. If you get under the car and look straight up along the edge of the firewall about where the clutch pedal is, you will see a grommet under there. That is where/how we ran the wires for my concealed radar install. It's a bit tough to see but under there and fairly easy to sneak the wires through into the cabin. One thing that might help locate it is to remove the panel under the steering column and look at the firewall from inside the car. You will see the grommet near the clutch pedal. That should help in locating it from the outside. You can actually push the grommet out from inside the car and shine a flash light through it which will help in locating it from under the car. It may help to have an extra set of hands to do this.
Old Mar 1, 2014 | 05:37 PM
Theta's Avatar
Theta
Thanks, slief!
I didn't see the other thread, but that's great info about the fender liner. I wasn't optimistic that it was accessible from the engine bay, and now we know.
Old Mar 1, 2014 | 05:54 PM
slief's Avatar
slief
Thanks, slief!
I got a PM from George a little bit ago. Evidently he found another way to get the wires into the cabin from the same general area. Apparently near the A-Pillar in his case. Maybe he can explain better.
The grommet I used was fairly easy to access once you knew where to look. I think it was for the clutch peddle or something but it was easy to snake the wires through and easy enough to access. We routed a radar sensor line and two diffuser lines through the same grommet.
Old Mar 2, 2014 | 03:40 PM
BillB3672's Avatar
BillB3672
Default Are you installing a curb detector?
If you are installing a curb detector then I have posted photos with embedded instructions on the forum. Search on the forum under (billb3672 Album) It shows the wire routing into the cabin through the door seals and not through the firewall!
Thanks, George
Old Mar 4, 2014 | 01:58 AM
george vee's Avatar
george vee
I could not find your pics but I did run the wires under the A pillar into the cabin. Thanks,George
To How do I get wire thru firewall
