6.2L DI engine in Silverado
Old Mar 3, 2014 | 02:09 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Default 6.2L DI engine in Silverado
There is a 6.2L DI aluminum block engine with AFM in the Silverado.
420 hp and 460 ft-lb torque.
It is called the EcoTech3. Is this the same engine as the LT-1 in the Stingray?
Other than obvious exhaust plumbing, what would the difference be?
Heads?
I just sold a 72 LT-1 which has tags "LT ONE". I was wondering if it would be incorrect to use the tags on the 6.2L Silverado. (Don't want the PC Police to come get me)
Any help?
Old Mar 3, 2014 | 02:34 PM
arcticblast
I think I may have found it. It's called the L86 in the Silverado.
Old Mar 3, 2014 | 04:03 PM
CPhelps's Avatar
CPhelps
As you found, it is the L86. It is related as they are both Gen V V8s, but they have differences based on their intended applications.
This article compares the truck engines to the Corvette engine: http://www.enginelabs.com/news/corve...uch-in-common/
Old Mar 3, 2014 | 04:39 PM
yonson's Avatar
yonson
Yup it's the same engine other than the intake, oil pan and accessory drive.
Old Mar 3, 2014 | 09:28 PM
breecher_7's Avatar
breecher_7
Yup... I have one sittin in my driveway... It's to bad the accessory drive is not the same as the vette, I would have a ecs bracket on it already if it was!
Old Mar 4, 2014 | 03:30 PM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
we have truck whipple kits on the way :P
Old Mar 4, 2014 | 03:39 PM
Daniel@Vengeance's Avatar
0Daniel@Vengeance
Former Vendor
From what I see on Chevy's site, it is still not available in a RCSB
Otherwise I'd be on my way to order a new truck!
Old Mar 4, 2014 | 08:49 PM
ChucksZ06's Avatar
ChucksZ06
That is what I was going to do...then I got a chance to get the c7 early. I told a friend that I wanted the 6.2 di engine and it happened to come first in a vette instead of the pickup.
Old Mar 4, 2014 | 09:23 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Damn the bad luck!
Old Mar 10, 2014 | 11:59 PM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Anyone have one near NYC
We are looking for one.
Old Mar 11, 2014 | 08:26 AM
NemesisC5's Avatar
NemesisC5
Cam and exhaust manifolds are different as well.
Old Mar 11, 2014 | 11:16 AM
yonson's Avatar
yonson
You are correct the manifolds are different, I'm pretty sure the cam is the same however.
Old Mar 11, 2014 | 11:28 AM
PCMusicGuy's Avatar
PCMusicGuy
You can bet a variation of the 8 speed transmission will show up down the road too.
Old Mar 11, 2014 | 03:22 PM
yonson's Avatar
yonson
Yeah, they both use the same cam, 12629512.
To 6.2L DI engine in Silverado
