Clutch engagement too high
Old Mar 8, 2014 | 02:02 AM
panerainovice's Avatar
panerainovice
Default Clutch engagement too high
Anyone having this problem? Seems like my clutch is engaging past the 50% mark. Seems like a few people notice this and others are just trying to adjust to it.
Is there any way to adjust the clutch to engage earlier? I'm use to it engaging around 35-40% on the way up.
Old Mar 8, 2014 | 06:26 AM
gthal's Avatar
gthal
Mine feels like it engages pretty close to most any of the manual cars I've owned... fairly high in travel, as you point out, but no different than my BMWs.
Old Mar 8, 2014 | 08:20 PM
RedCarrot's Avatar
RedCarrot
I, too, feel the clutch travel is unnecessarily long. So often starting from a dead stop, I find myself releasing the clutch half way before applying gas. By my estimate, using a 1-10 scale with 10 being the clutch pedal all the way up, it feels to me the clutch begins to engage at the 7 mark.
I have a different approach for a solution though. Instead of adjusting the engagement point, which doesn't shorten the travel itself, I am opting to place a block (1 inch thick foam core wrapped in terry cloth-like material) behind the clutch arm so that it won't travel below the 3 mark. I have done this with my S2000 in the past and it worked well with no advanced clutch wear that I was aware of in 70k miles.
Old Mar 8, 2014 | 08:42 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
You will have to ensure it passes the "clutch depressed test" to start the engine.
Old Mar 9, 2014 | 09:42 PM
RedCarrot's Avatar
RedCarrot
Oh I am more worry that the engine would start but the clutch is still not fully released to cause advanced wear over time. It shouldn't but I can't know for sure. That's why I am going to error on the side of caution to cut the travel by only 30%. By feel, it seems the clutch starts to engage at the 7 mark (quite possibly 8) and that the last half of the travel is unneeded.
To Clutch engagement too high
