Radiator Fins / Damage
Old Mar 18, 2014 | 05:01 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Looks like I got lucky this time.
Note to anyone doing work near the radiator - use two sheets of cardboard. One isn't enough.
Old Apr 19, 2014 | 05:41 PM
RickMN's Avatar
RickMN
Presuming you are not building some kind of show-car engine compartment that needs to be pristine to compete, I would just leave it be.
Pulling the unit is likely to cause even more dings and bent fins. And you will still have to worry about leaks when you connect it back in again. I would fill it up and see if anything drips out. Even if it leaks someday, it will be a slow leak.
