Wheel question
Old Mar 18, 2014 | 10:52 AM
joecub22's Avatar
joecub22
Default Wheel question
If I have standard C7 wheels on my Vette can a put on Z51 wheels without any other altercations?
Old Mar 18, 2014 | 11:19 AM
savage's Avatar
savage
Default yes, too easy
here is something i learned today, im a fitment nut so in trying all the wheels in my shed from all my sold corvettes just for my own F.Y.I. and as i was putting my stock wheels back on my non z51 c7 i grabbed a rear tire to just see how it looked on the front and it would not go on! long story short- fronts fit front and back, backs fit back only. F.Y.I.
Old Mar 18, 2014 | 12:07 PM
Kracka's Avatar
Kracka
Honda S2000 wheel fitment is the same.
Old Mar 18, 2014 | 05:18 PM
LT1xL82's Avatar
LT1xL82
How so? Different bolt pattern? Or is it a clearance issue with calipers or whatever?
Old Mar 18, 2014 | 05:28 PM
yonson's Avatar
yonson
Meaning what?
On an S2000 you can run the rear (S2000) wheels all the way around, but you either need to bore out the hub or run a 5mm spacer with the correct bore. You can even run a 9" wheel all the way around without clearance issues as long as the offset is correct.
Old Mar 19, 2014 | 08:51 AM
savage's Avatar
savage
Default clearance issue with calipers
bolt pattern is same, bolt pattern on corvette has not changed in years. F.Y.I. bolt pattern is the same as my 1998 blazer s/10 plow truck.
To Wheel question
