Loud ticking in V4 mode
Old May 11, 2014 | 07:30 PM
NoOne's Avatar
NoOne
Default Loud ticking in V4 mode
Little things are starting to pop up. Just over 1900 miles and today we did our first extended trip in ECO mode with it running in 4 cylinders most of the time.
Turned down the radio because I heard a loud ticking noise coming from the left side of the car. At 80mph, cruise on, 7th gear. Sounded like an exhaust tick. Touch the gas to put it back in V8 mode and its fine.
Left it in V8 mode for a bit, then put it back in ECO, no problems till about 50 miles later, then the tick returned.
That and now my auto exit died. Hit the button today, car beeped a few times, now the button no longer operates even though Easy Exit is turned on, doesn't do it when you turn the car off, or hit the button. It does return to position when you hit 1 and when you open the door.
Anyone else seen/heard this tick?
Old May 11, 2014 | 08:41 PM
kp's Avatar
kp
Since I have an auto and its in V4 mode often I noticed the V4 ticking a couple days after I had it. It will do it around 1400 and 1700rpm and it sounds like a header leak - it can get pretty loud. Give it a little more throttle and it bumps into V8 and goes away.
I can stall it up in 3rd gear standing still to 2000rpm and there is no noise at all, AFM wont kick on of course sitting still.
I think its just some exhaust weirdness, the AFM valves are closed it just may be some noise in the headers or cats. Some guys have blamed it on the belt tensioner but I had a bad belt tensioner that leaked all the oil out it was more of a screech/chirp in V4, different from the exhaust leak sounding tick.
Its pretty embarrassing at times, sounds like an old car with a cracked exhaust manifold sometimes. It runs fine, seems quick enough and gets 30mpg on the highway so I'll live with it. If it is something in the valvetrain GM has 4.8 years and 96,000 miles to worry about it, not me
Old May 23, 2014 | 10:30 PM
ShibbyC7's Avatar
ShibbyC7
7th Gear
You are not the only one. I noticed the same ticking or what I would call a clattering sound coming from the engine while at the apex of 1/4 mode. Mostly while cruising at highway speeds. Just before bumping back into 1/8 where the engine needs more power, the motor will sound like it is pinging with poor quality gasoline.
I tried to tell myself that I purchased a bad tank of gas. It didn't go away after the next tank. It is getting louder and is very unnerving when it happens. I'm almost always find myself stepping harder on the accelerator to bump into 1/8 or paddle shift into a lower gear before it happens now. I'm also noticing a slight lurch before dropping back into 8cyl from 4cyl, but that may be just me being over sensitive.
I picked her up in December and just broke 11k miles. Yeah, I know I've driven her quite a bit, but she isn't going to be a garage queen. All the fluids check out fine. Does anyone have any ideas or recommendations other than just taking her back to the dealership for diagnostics?
Shibby...
Old May 24, 2014 | 03:48 PM
Mr Guns's Avatar
Mr Guns
Mine has a tick at certain rpms, and you can also hear it when idling. Haven't noticed in V4 mode as I haven't really used it. From the other threads I've seen, this is due to the direct injection and is normal.
Old May 24, 2014 | 05:22 PM
noel48's Avatar
noel48
St. Jude Donor '14
Sounds like belt tensioner failure.Several of us got bit by this.Take to dealer.
Old May 24, 2014 | 05:37 PM
ShibbyC7's Avatar
ShibbyC7
7th Gear
Thank you for the reply. I'm scheduling a visit and will update the thread with results.
Old May 24, 2014 | 06:01 PM
kp's Avatar
kp
Its not, at least on my car. I'm on my 3rd tensioner and they have all done it. Finally got one that didnt leak. When the first tensioner leaked out all the oil it chirped pretty loud in V4.
The tick has always been there on my car, and still is right after replacing the second leaking tensioner.
Old May 24, 2014 | 06:25 PM
NoOne's Avatar
NoOne
DI motors do tick, that's normal.
This is not a DI style tick. This is loud and very pronounced, sounds like a bad exhaust leak.
I'll have the tensioner checked when it goes in on Tuesday. Is it primarily from one side of the motor? Mine is from the drivers side.
Old May 24, 2014 | 06:56 PM
SailDoc's Avatar
SailDoc
3rd Gear
I noticed this about 2500 miles. Tracked it to the transition from V4 to V8 by watching the display that shows V4 or V8. Just before the transition, I would hear a loud ticking noise that sounds like cylinder knock due to bad or low octane gas. After the transition to V8, the noise disappears. I fixed this temporarily with a Diablo Sport Tune that locked the car in V8 mode. Noise hasn't recurred since, but I'm planning to put it back into stock tune and return it to the dealer for diagnostics when its time for an oil change.
Old May 24, 2014 | 08:00 PM
runutzzzzz's Avatar
runutzzzzz
Sounds normal. Mine has done that since 1k miles and the dealer said it was normal. I'm thinking you are hearing the DI since you're at a low RPM cruising.
I've had bad gas before and the car would sound like it was knocking, really loud!
Old May 24, 2014 | 08:15 PM
kp's Avatar
kp
I think its something happening in V4 mode, with the afm valves closed it may be doing something in the exhaust. Could also be the lifters bled down too I guess.
Its really easy to hear with the roof off going around 40mph on a side street, it sounds like it comes from the LH side and its pretty loud. Its a little too constant to be detonation, sounds like a header leak or a cracked exhaust manifold. With an auto you can put it 3rd gear and stall the converter to past 2000rpm and you dont hear it all s its not an exhaust leak. Only when driving and its in V4 at a certain RPM.
If I'm driving at a speed where I hear it a lot with the windows down or top off I just put in in manual mode. With the windows up, radio and AC on I dont hear it.
Wonder if anyone hears it with a manual trans and not in ECO mode (no AFM) or if its more an auto thing since the V4 is active a lot
Old May 24, 2014 | 09:47 PM
NoOne's Avatar
NoOne
Mine is a manual and I only hear it in ECO in V4 at freeway speeds. I hear it between 70 and just over 80mph.
Old May 24, 2014 | 10:39 PM
shftn7's Avatar
shftn7
Mine is auto and hear at all times in v4
Old May 25, 2014 | 01:47 AM
kp's Avatar
kp
I bet if you look at the rpm at that speed and if you can get it to go in V4 in a lower gear at at the same rpm and lower mph you will hear it too. Mine is the worse at ~1200 and ~1700rpm, when it goes into V4 and you give it a little throttle and it doesnt go back into V8.
Old May 25, 2014 | 08:45 AM
Theo Harris's Avatar
Theo Harris
I do not get the constant ticking noise on my C7 Z51
However when transitioning from V8 to V4 in ECO MODE I get a loud noise and a small jerk, is that normal?
I have manual 7 speed
Old May 30, 2014 | 10:16 PM
ShibbyC7's Avatar
ShibbyC7
7th Gear
Noel48 was correct! The issue according to the dealership and GM was a bad TENSIONER. They replaced it today and the rattle is gone. I'm planning on taking it for a long cruise tomorrow but she rode home tonight without a hitch.
T.A.C. Case Number 71-1311786318
Old May 30, 2014 | 11:51 PM
Wormwood's Avatar
Wormwood
Sorry, I started to notice this ticking after I had the belt tensioner replaced. I thought I was losing my mind, it sorta sounded like an exhaust leak but couldn't localize the sound anywhere under the car.
I purchased one of the RANGE V8 plugin modules & it's taken care of the noise. Whether this is a bandaid fix or a true solution, I don't know, but so far so go.
Wormwood
To Loud ticking in V4 mode
