Efilive tuning C7
Old May 22, 2014 | 01:23 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Default Efilive tuning C7
Just off the EFILIVE website---They have reports of some FRIED ECM's that were previously tuned with Diablo and then re-tuned with EFILIVE
They have sent out a warning to all Commercial tuners NOT to re-tune any C7 that has previously been tuned with Diablo--
Take the word for what it's worth---It is extremely difficult to get a NEW C7 ECM if yours fries
ALSO report of tuning with EFILIVE without even touching the timing tables or fuel tables and working with "Torque Response" only has netted an incredible 25-30 RWHP gain average !! Stock automatics with NO mods are getting 440 RWHP----
The new world of SIDI tuning is amazing--- The ECM does all the work for you--Fuel and timing---All you need is to "ask for more TQ and the ECM tries to get it---
Check out the EFILIVE website to confirm----
Old May 22, 2014 | 10:18 AM
WKMCD's Avatar
WKMCD
Not good. I will be setting up the car with EFILive. I'll skip the Diablo.
Old May 22, 2014 | 10:39 AM
VAmikeC7's Avatar
VAmikeC7
Definitely will want Mike from Diablosport to check in on this. Sounds fishy since many people on here have the diablotune.
Old May 22, 2014 | 10:42 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I think the full context is if you have a Diablo Tune, put it back to stock BEFORE you tune it with ANY tuner program. I believe the issue was trying to tune the E92 with an existing Diablo tune still sitting in the ECM and they were making paper weights of the ECM.
The problem is with the system Diablo is using to make sure the checksum is correct to disguise any tuning work on the ECM. This "system" confuses the EFIlive boot loader and the E92 goes belly up. No problem if the original stock tune is loaded back into the ECM.
https://forum.efilive.com/showthread...ghlight=diablo
Elmer
Old May 22, 2014 | 10:54 AM
VAmikeC7's Avatar
VAmikeC7
Elmer
Thought the same thing. It would be the most logical and common sense thing to return the car back to stock before putting another tune on it.
Old May 22, 2014 | 11:51 AM
Ron@Vengeance Racing's Avatar
0Ron@Vengeance Racing
Former Vendor
This isn't anything new.. You can turn an E40 or E38 into a paper weight if you try to write over a Diablo (or any other hand held for that matter)
As said above, return the ECU to stock prior to doing anything with EFI Live or HP Tuner and you should have no issues.
Old May 22, 2014 | 04:44 PM
ProChargerTech's Avatar
0ProChargerTech
Former Vendor
Exactly!
Old May 22, 2014 | 05:41 PM
killascrimp's Avatar
killascrimp
ya you make it sound like "Beware of diablo" That is just common sense. What do you expect flash then flash with different software. I am happy with my Trinity... Have fun with yours..
Old May 22, 2014 | 05:58 PM
yonson's Avatar
yonson
If anything EFI Live should detect the non-factory calibration and not allow the PCM to be written to. Diablo has been doing this for years...
Old May 22, 2014 | 06:02 PM
Vettefan666's Avatar
Vettefan666
Elmer
I hope you're right. This is EXACTLY my situation. Also, it would be good to know when
we'll get access to ALL the tuning tables. We can't even turn off CAGS.
Old May 22, 2014 | 11:36 PM
0Vengeance Racing
Former Vendor
Nothing new here
Diablo does not play well with other software. Been that way for awhile.
Old May 23, 2014 | 12:09 AM
Skunkworks's Avatar
Skunkworks
So how would somebody doing simple tweaks (minor changes) to a previously tuned car go about this? Revert back to stock on a heavily modified car and reinvent 90% all over again?
Old May 23, 2014 | 02:06 AM
yonson's Avatar
yonson
Read out the tuned calibration with EFI, HP etc... then put the car back to stock with in this case the Diablo, read out the factory calibration with EFI, HP etc... and make your changes to it. It's a couple extra steps, but I've never had any issues that way...
Old May 23, 2014 | 02:11 AM
tblu92's Avatar
tblu92
I always keep a copy of the STOCK and retuned files-If you had Diablo flash some changes along the way--Just re read the ECM again now that will have all the added updates that it currently has--
Then run a comparison analysis summary between the 2 tunes and a history list will pop up showing each table that has been made
You also can get most all STOCK GM tunes from tunefiledepo.com---then compare that tune to the current one---
Not sure if I answered your question--
To Efilive tuning C7
