Rotating the crank
Old May 25, 2014 | 02:34 PM
Wormwood's Avatar
Wormwood
Default Rotating the crank
I'm trying to manually turn the crank & the electronic steering rack is in the way for a socket on the harmonic bolt. Anyone have a quick & dirty on turning the crank manually?
I doubt a crows foot would work, but maybe a strap wrench around the harmonic damper might...
Thanks,
Wormwood
Yes, I have the plugs out & I'm cleaning the intake valves by hand so I'm needing to rotate to get the intake valve closed..
Old May 25, 2014 | 03:45 PM
Higgs Boson's Avatar
Higgs Boson
hook up a bump switch. quick button tap that bumps the starter.
Old May 25, 2014 | 08:08 PM
ChucksZ06's Avatar
ChucksZ06
A large screwdriver. Pry against the flywheel teeth easily turns over the engine.
To Rotating the crank
