How does the Emergency brake system function mechanically
Old May 25, 2014 | 04:09 PM
Mosler MT 900S's Avatar
Mosler MT 900S
Default How does the Emergency brake system function mechanically
I was hoping someone could explain how the emergency brake system works.
I looked and did not see a dedicated caliper so is it a drum on the inside of the rotor.
The hill assist seems like it might use some sort of line lock. Maybe part of the abs system.
Is the noise I here an actuator if so what is it pushing.
I am trying to eliminate the manual parking brake on another car I have and the aftermarket doesn't really offer anything that could be used. I have found electrically actuated calipers but they require a computer to operate.
I have found another system that is just a linear actuator that pulls on the existing cable.
I am currently thinking a line lock might be the easiest using a linear actuator to move a valve. Operation would be to hold the brakes, actuate the system and it would hold the existing calipers. I would have a safety release in case the line lock failed.
Thanks for the help in advance
Old May 25, 2014 | 08:00 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Old May 25, 2014 | 08:06 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
The system is very similar to the C6 ie mini drum with mini shoes.
Of course the difference is the cable is pulled my an electric actuator on the C7.
Old May 25, 2014 | 09:04 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Old May 25, 2014 | 09:39 PM
Mosler MT 900S
It does sound like a linear actuator. Somehow I need to find a lift to get a look so i can copy it.
Old May 25, 2014 | 11:01 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
I'll get some info for you since you're curious. Stand by.
Old May 26, 2014 | 01:21 AM
Theta's Avatar
Theta
Old May 26, 2014 | 01:27 AM
Theta's Avatar
Theta
Old May 26, 2014 | 01:39 AM
Theta's Avatar
Theta
Old May 26, 2014 | 01:43 AM
Theta's Avatar
Theta
Old May 26, 2014 | 01:49 AM
Theta's Avatar
Theta
Old May 26, 2014 | 01:52 AM
Theta's Avatar
Theta
Theta's Avatar
Theta
Maybe I took that one too far? ...
Old May 26, 2014 | 08:41 AM
rjwz28's Avatar
rjwz28
Old May 26, 2014 | 12:56 PM
Magister Ludi's Avatar
Magister Ludi
Wow!
No such thing as too much info. Thanks.
Old May 26, 2014 | 01:28 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Would you happen to have those picture in color? Black & White is so blah!
There is no "too far" in a complete answer.
Elmer
Old May 26, 2014 | 02:12 PM
$$$frumnuttin'
no, you need to explain the sentence regarding...checks to see if in the proper temperature range...WTF is that all about?
so, how do you like your Tech Con status now?....
Jerry (your sponsor)
To How does the Emergency brake system function mechanically
Old May 26, 2014 | 02:32 PM
RicK T's Avatar
RicK T
Nooooo!
Very cool of you to do that. Thank you much! Bookmarking for future.
Old May 26, 2014 | 03:58 PM
Theta's Avatar
Theta
I could pull a Ted Turner and colorize all of it (badly)!
You make me sound like an alcoholic....
Old May 27, 2014 | 10:46 AM
RonC7's Avatar
RonC7
Default This should be a sticky!
This is great information. I don't know that I will ever attempt repairs on this car, but the background info is fascinating.
This should be made into a sticky of some sort.
Thanks Theta!
