Bottom or mouth feeder
Old May 26, 2014 | 02:02 PM
dckotwicki's Avatar
dckotwicki
Default Bottom or mouth feeder
Is the C7 base getting most of its cooling air for its mouth or the bottom?
Old May 26, 2014 | 02:04 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Every single bit from the front grill!
Old May 26, 2014 | 04:41 PM
Modshack's Avatar
Modshack
And it looks like only 1/3 of the air is exhausted through the hood vent based on the shrouding....
Old May 29, 2014 | 07:18 PM
TEXHAWK0's Avatar
TEXHAWK0
If you look under the nose of the front bumper you will see that it is completely closed in. No opening like in the C5.
Old May 31, 2014 | 12:04 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Cooling air comes through the grill and the hot air goes out over the car. Unfortunately, while it does that, it most likely heats up the air intake as the intake is directly under the air extractor in the hood and parallels the radiator. Hello heat soak
The question should be how do we get cool air into the intake tract
Old May 31, 2014 | 01:29 AM
Motohead279's Avatar
Motohead279
Meth injection.
To Bottom or mouth feeder
