7 speed shifter chatter.
Old Jun 17, 2014 | 01:02 PM
belljetranger's Avatar
belljetranger
Default 7 speed shifter chatter.
took delivery at museum in late may. noticed chatter in 1,2,3, and 4th. the chatter deminishes on up into 7th. Anyoine had this problem?
Old Jun 17, 2014 | 01:28 PM
RussM05's Avatar
RussM05
The first thing I would check is the shifter box mount bolts to the torque tube. If the shifter has a lot of play right to left when in gear, that should be a clue.
To get to them, you have to remove the console cover. There is a sticky to show you how.
The shifter is bolted to the torque tube with Torx 40 bolts. Sometimes, they come loose or were not properly torqued in the first place.
Good luck.
Old Jun 17, 2014 | 10:37 PM
SnowyATX's Avatar
SnowyATX
Do you hear it or feel it or both?
Mine will buzz if my ring touches the metal cap on the shift ****. Nothing other than that here. VIN 23,916
Old Jun 17, 2014 | 10:39 PM
Theta's Avatar
Theta
St. Jude Donor '14-'15
Good luck.
Seconded. Worth a look.
Old Jun 30, 2014 | 06:39 PM
TEXHAWK0's Avatar
TEXHAWK0
I have an aftermarket shifter without any rubber vibration dampening, and I have no noticeable vibration in the shifter.
I expect most people will have some vibration, but a heavier **** usually gets rid of it.
Old Jun 30, 2014 | 10:21 PM
RussM05's Avatar
RussM05
If it's the MGW then then the rubber vibration damper is on the outside of the shaft nylon bushings.
Old Jul 10, 2014 | 08:02 PM
TEXHAWK0's Avatar
TEXHAWK0
I have the modified Hurst style shifter from Core shifters.
Old Jul 10, 2014 | 08:56 PM
RussM05's Avatar
RussM05
I've worked on many C5, C6, and now C7.
They look simple but they are tricky to diagnose especially remotely.
First, make sure all the bolts are tight. Look for stripped threads on the shifter box where the shifter is attached. They can easily strip the hole and to fix, red rill to a bigger size and retap.
Next, make sure the bottom of the shifter is solidly wedged in to the slot on the torque tube. Try wiggling the shifter right to left. If the box moves around more than a fraction, it's not wedged in there firmly enough. There is a black plastic piece on the bottom. It is attached to the box with RTV. Remove it an add more RTV there to make a tighter fit.
Finally, if you are using the stock box, replace the two upper bushing with the aftermarket rubber bushing. These provide a more solid connection to the torque tube yet still dampens the vibration. You can find them on eBay, JW motoring, RPI, and other vendors.
The **** must be solidly attached to the shaft.
To 7 speed shifter chatter.
