Any recommendations for tires?
Old Jul 15, 2014 | 04:29 PM
Elite '14's Avatar
Elite '14
Default Any recommendations for tires?
I am currently running ARH 1 7/8" without cats. Waiting on delivery of my ECS and Alky Control kits. Looking for some tires to fit the z51 wheels. I will go to the drag strip once or twice but virtually all driving will take place on the streets. Thanks in advance.
Old Jul 15, 2014 | 04:58 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
Toyo r888
Old Jul 15, 2014 | 06:18 PM
Elite '14's Avatar
Elite '14
Originally Posted by Frans96ss
Toyo r888
I spoke to TireRack and they told me that those tires wouldn't work with the Z51 wheels. Something about the overall tire diameter needing to be only a 1inch difference between front and rears or the "computers" in the car would not be able to manage the torque properly.
Forgive me for my ignorance on the subject.
Old Jul 15, 2014 | 09:47 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
We have used them plenty of times with out a problem. I see them a lot on C7's. Tire rack will also tell you anything other than the stock size wont work.
Old Jul 15, 2014 | 10:14 PM
Elite '14's Avatar
Elite '14
Fair enough. Any idea for how long they are meant to last given the driving conditions I originally listed?
Old Jul 15, 2014 | 11:39 PM
shftn7's Avatar
shftn7
Currently running them. The rear is 285/35/20 instead of 30 for the profile. They hook quite well at track but they do hummm some on the street.
Old Jul 15, 2014 | 11:55 PM
Elite '14's Avatar
Elite '14
Thank you shftn7. If you don't mind:
Roughly how many miles do you have on them?
Are you running a different tire up front?
Old Jul 15, 2014 | 11:57 PM
Elite '14's Avatar
Elite '14
The exhaust makes all of that hummmm just disappear!!!
Old Jul 16, 2014 | 11:36 PM
Arnett24's Avatar
Arnett24
6th Gear
I have the exact same set up as you. I went with the nitto 555r's in the size 305-35-20 and they rubbed bad. Every turn and/or bump they would rub. They even rubbed while my car was on a dyno. At first I thought it was the width that was causing the rubbing but it was actually the thickness. You basically cannot use a larger diameter tire than the stock ones or they will rub. Just a little heads up so that you don't make the same mistake I did!
Old Jul 16, 2014 | 11:52 PM
Skunkworks's Avatar
Skunkworks
R888 are a great tire, but don't expect miracles if you have enough power. That being said I have R888 but Hoosier A6 or R6 is better.
Old Jul 17, 2014 | 01:23 AM
Elite '14's Avatar
Elite '14
Thanks for the input. Do you recommend running the same tires up front or doesn't matter?
Old Jul 17, 2014 | 01:38 AM
shftn7's Avatar
shftn7
So far about 300 miles. I have been to the track and brought my 1/4 time down by .6 with just the tire change. Flooding rain tonight I got caught in and the r888's did great.
Lol as long as you are I track or sport mode yes
Old Jul 17, 2014 | 01:41 AM
shftn7's Avatar
shftn7
I am not sure on a lowered car but mine is at stock ride height with 285/35/20 and I have a good inch before they would rub.
True but they hook with little 600rwhp. Went from a 2.3 60ft to 1.8.
Old Jul 17, 2014 | 01:46 AM
Elite '14's Avatar
Elite '14
That's a huge difference! What ET did you end up running?
I am planning on picking them up tomorrow. Do you run them up front too or just in the rear?
To Any recommendations for tires?
