Does the C7 have a CAN Buss?
Anyone know????????
Anyone know????????
http://www.betweentheaxles.com.au/co...hd-videos-4221
Anyone know????????
As in a previous thread, I am looking for an output to give me pulses when the vehicle is in motion. I have found a module by Racelogic that will tap into the CAB bus and has speed and RPM outputs. I'm just trying to get that signal. If I can tap into the CAN bus signal from the OBD II port, that would make life so much easier than tracing down a wire. The Racelogic rep in the US hasn't responded to my questions, and I have sent an email to the UK distributor. The UK site has several options that may work, including a model that hooks up to the OBD II port.
http://sailesmarketing.com/products/can-bus-interfaces/
I have until next April before I need this gizzmo in the Big Bend Open Road Race, but would like to get it up and running for some testing.
The software is just about ready for testing. I can do that on my C6. But a friend would like to have the system in his new C7 for next year's race.
There is a limit on refresh rate, but if I remember correctly, it's around 50ms (20 updates/second) - more than fast enough for what you're wanting.
I can probably get to some testing this weekend. Also you can get faster than a PID every 50 ms updates.
OBDII is/was limited to 10,400bps - the rule used to be 18 I/O /s before CAN.
EDIT - most scanners likely impose a limit to be safe...
At 100 times faster, CANBus would allow 8000 round trips, so you're right - it's pretty much wide open up to the limit of the tool.
In most cases CAN bus is shared by multiple modules so depending on network load you’ll see limit imposed by other modules, because xx% of bandwidth is gone in normal operation.
To OP, Mode and PID address in hex. A standard packet is 8 bytes of data in length, not including overhead…
You guys are way over my head. I'm more of s mechanical type, than an electronic/computer type.
Theta, on your C7 schematics, can you locate the PCM C2 Pin 50? My friend that is developing the software, tells me that this is the VSS signal. If so, where is the PCM located, and where would be the best place to tap into the wire from pin 50? (in the C6, it is circuit 817, green w/white wire, and I taped into it behind the radio)
I was able to find a module to convert the OBD speed signal to pulses, but my friend tells me it wouldn't be accurate enough the way it derived. I need it to be as precise as I can get it. In my C6, during the Big Bend Race, I was only off 52 ft in 59 miles. I was trying to stay in my lane as much as I could, since that is where I measured the course (Highway) to begin with. On Race Day, at 100+ I didn't have to stay in my lane, and after looking at the video, I didn't.
