C7 Fuel System Upgrade
Old Jul 27, 2014 | 08:53 AM
spaceaholic's Avatar
spaceaholic
Default C7 Fuel System Upgrade
Any idea who offers fuel system upgrade kits and whats involved in their installation?
Old Jul 27, 2014 | 09:51 AM
Higgs Boson's Avatar
Higgs Boson
cam lobe
Old Jul 27, 2014 | 09:53 AM
spaceaholic
Originally Posted by Higgs Boson
cam lobe
Is a cam replacement the only option?
Old Jul 27, 2014 | 11:17 AM
Higgs Boson
so far. that's why everyone bolts on a supercharger and makes basically the same power.....550-600 whp depending on the dyno. if you want to make more you swap the cam and if you swap the cam you might as well do the heads.....if you are spending enough for that you might as well pop for a stroker motor. now you make 1000 hp.
Old Jul 27, 2014 | 11:58 AM
jerho's Avatar
jerho
Then what about the rear end and trans?
Old Jul 27, 2014 | 01:25 PM
Unreal's Avatar
Unreal
Not the only option, but the best option.
LPE does make an injector drive to add port fuel injectors. Also any standalone could drive a set of injectors if you want to added them. You would need a custom intake manifold/rails/etc. You could also use methanol as fuel if you want to go that route and either do 1 or 2 nozzles pre TB or a direct port meth setup and use it to supplement fuel to the motor.
I believe DW has upsized injectors too. No real feedback on how well they work or the limits.
Old Jul 27, 2014 | 01:58 PM
Higgs Boson
the stock clutch, rear, and trans seem to be holding quite a lot of power without issue that I know of.
Old Jul 28, 2014 | 09:07 PM
Late Model Racecraft's Avatar
Supporting Vendor
We have our own custom made fuel system for our packages only at the moment. Soon we will be able to release to the public but for now only being installed on customer vehicles.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
Old Jul 28, 2014 | 09:41 PM
Cordes Performance Racing's Avatar
Supporting Vendor
Like everything you guy's make, it'll be super nice i'm sure
To C7 Fuel System Upgrade
